Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Heater tries to light but shuts off - Jandy Lite 2 Natural Gas Pilot Light Heater
    Top Expert:
  • Jandy Master
  • 5,045 Answers
Check flame sensor
Posted on Apr 29, 2016
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: GOT THE HEATER RUNNING FOR 5 HOURS YESTERDAY BUT
Hi Barry,
Turn off al power... drain the header manifold. Remove the top cover and remove the pressure sensing line from the pressure switch. Clean out the line and the manifold fitting with a piece of wire. Reinstall manifold drain plug. Reconnect rigid pressure sense line to manifold and pressure switch. Make sure the sense line does not leak or it can cause the unit not to heat at all. Leave the power for the heater off and circulate water for a few minues to flush header manifold then Test the unit. If this does not correct the problem... respond with the complete model number and we can continue troubleshooting.
Thanks for choosing FixYa,
Kelly
Posted on May 24, 2011
  • 990 Answers
SOURCE: my heater started with no
If you have a by-pass valve be sure it is closed or almost closed. Also check your baskets and clean your filter. All of these will give the heater low pressure and keep it from running.
Posted on Aug 15, 2011
WE HAVE A COZY GAS HEATER HAVE TRIED TO REPLACE THE THERMAL COUPLING AND THE HEATER LIGHTS AND SHUTS OFF AFTER FIRST CYCLE WHAT ELSE COULD IT BE IT HAS A HEAT SENSOR ON THE BACK COULD IT BE THAT
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 22, 2010 | Cozy (VCR502A-BM) Heater
Our gas was shut off and when it was shut back on the tankless water heater not working. I can hear the pilot clicking but no flame.
Since it was turned off, there is probably some air in the lines, which may require several attempts to light it again. This is normal, especially on longer gas lines. If you have any other gas appliances, (furnace, stove) try lighting them also to help purge the gas lines and eventually it will get the right mixture of gas to relight the water heater too. Douglas
Jun 10, 2010 | Bosch & Tankless LP Hot Water Heater
Heater Wont light
If it has been off for a while you probally just have to bleed the gas line out. Shut off the gas valve at the heater and then open the union at the heater. Turn the gas back on till you can smell gas. Shut it down and close the union then turn the gas back on and try it again.
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
My pro comp heater will light the pilot but will not light the heater. It just sparks attempting to light, after a while it will shut off completely.
Could be your thermocouple. The spark should light the pilot and the pilot lights the main burner but if the thermocouple doesn't pick up the heat from the pilot the igniter will keep trying to light it until it times out and shuts off to prevent gas buildup.
Mar 10, 2010 | Procom MN300EPC Heater
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Dec 11, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
My heater will not burn unless you hold the knob in once release it shut off
Are you getting the pilot light to work? some gas valves are finicky about where the knob is positioned when trying to light the pilot.
Dec 31, 2007 | Heating & Cooling
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
51 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
