It woks fine when I warm it up with a hair dryer
SOURCE: LG 42PG20 42" Plasma.
i have seen on some of those models bad power supplies. if you take the back off the tv you wil see a board in the top center that is the power supply board. you may have about 8-9 vented capacitors towards the left hand side of the board. they will look like they are exploding on the top some may even have black residue on the top that is the leaking electrolytic fluid. they will proabaly be 3300micro farad at 16volt high temp 105degree capacitors.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
-0--0
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
