i have nec gigabyte n4 ibfgl v 1.2 mother board . i have format the pc & had install windows service pack 2 but now only audio sound & lan that is internet connection was not working
There is aset opf pins left of the blue HDD SOCKET that indicate the power led , hdd led and so on.
I have a front panel usb socket but havent had time to work out the cable config. Let you know when I get to it. This is not a bad little MB if you want just want for internet and W/Processing.
check your cmos CR2032 battery on the motherboard as this can cause restarts because of bios settings,when booting press F2 or Del and check the date and time to see if incorrect.
Also it maybe a faulty driver causing the crash, you can tell the bios to halt on all errors instead of rebooting, this can be found in the main cmos settings menu normally below the list of drives and check to see if halt on all errors is enabled, this way you can try to see what is causing the reboots.
A little more info for your motherboard is required but you can decide for yourself at the link below as to which drivers you require, as you will need to look at the chip on your board as to know which driver you need.
http://www.nec-computers.co.uk/support/Search.asp
NO TIENE DRIVERS DE AUDIO
Hi.. can you send me the specs for the same...
