Question about Nikon D40x Digital Camera
Nikon D40 will not take pictures when in autofocus mode
I have a Nikon D40 that is less than 6 mos old. It will not let me take pictures when it is in the autofocus mode. When I try to take a picture, it will not stop trying to focus. There have been a couple of times that it has taken a picture when the lens is fullly extended, but not always. There is plenty of light, and it takes pictures fine in manual mode. I have changed the battery, taken the lens off, and put it back on, taken the memory card out and put it back in. I've completely reset it, and it still will not work. I just got it to work, but I have to push the AE-L AF-L button while I am taking the picture. Can you give me some advice on what to try, or what could possibly be wrong? Thank you.
  • 2 more comments
  • Anonymous Jan 01, 2008
    My D40 quit autofocusing with the kit lens, I put my telephoto lens on and it works OK.
    Is the kit lens bad?
    Dead in the water.
  • Patto777 Apr 14, 2009
    I noticed that my Nikon D40 lens 18-55 lens would not take a photo occassoinally now it wont take a photo in auto mode, but does in manual mode.
  • drvpkn Apr 16, 2009
    I can't take the pictures when lens is in autofocus mode; but in manual mode it is working. I have 18-55 lens.
  • capsengson Apr 23, 2009
    hi, i have a problem with my d40x. one day, while charging my battery, i had an opportunity to take a shot. what i did was i removed the battery from the charger even if it is not yet fully charged and placed it right away in my camera. after 2 shots, my camera suddenly turned off and from then i was not able to turn it on again. i tried ti reset the camera and still it didn't work. please help me. thank you
    arth
I had a similar problem recently with my D-40 and the 18-135 Nikkor zoom lens. When I put the kit lens back on, it worked fine so it turned out to be a problem with the lens. I took it back to the store and since it is less than a year old they are sending it back to Nikon to be repaired.
Posted on Nov 18, 2007
  • 101 Answers
Check for dust specks on the lens glass.
Posted on Oct 11, 2007
SOURCE:
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
Dec 05, 2015 | Nikon DSLR D90 Digital Camera
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
Sep 02, 2010 | Sigma 70-300mm f/4-5.6 DG Lens
My D40 Nikon lens
Having gone over a month without a response, I assume this is no longer an issue.
Apr 13, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 will not autofucus.
Check if the swithch on to your left on the lens set to 'A'. If it is set to M this will be in manual mode and autofocus does not take place.
If this doesn't help, try removing the lens and re-fixing it firmly and properly.
Trust this helps.
Dec 16, 2009 | Nikon D40x Digital Camera
Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
Nov 27, 2009 | Cameras
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
No pictures when in autofocus mode
I was having the same problem with my D40... but I read your post, tried switching the 18-55 lens to manual, then back to auto, and it seems to be working fine now. Hmmmm... think maybe there's a circuitry issue with the lens?
Nov 11, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
478 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
