Question about Lexmark X5150 All-In-One InkJet Printer
Printer wont take paper
Hi my printer won't take in any paper, i have to like push it in manually page by page and thats not even working now, the LCD keeps saying "load paper and press select" the problem is just getting worse, please help.
  • antleon Nov 07, 2007
    hi paper keeps jamming what can i do to fix the problem
The paper go in on one side and jams
Posted on Nov 07, 2007
Yah i have the same problem... Its a Piece of [email protected]#T.  The Lexmark support said to clean the take up roller with a moist Q-tip.  It helps but you need to do it every time you print and it still clogs.
Posted on Oct 16, 2007
SOURCE:
My printer simply wont print, I just get blank pages even when printing the test page. I have tried cleaning, deep cleaning nozzle alignment, everything!
HI there,
It sounds like you've done everything right, and it still won't print. Your printer is dead - and you need a new one.
May 19, 2011 | Office Equipment & Supplies
Hi, my canon i80 printer wont feed paper through
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Sep 16, 2010 | Canon i80 InkJet Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
My canon mf8100 series prints once, then beeps and
set the paper size to A4 in ur computer and in ur printer
Aug 29, 2009 | Canon MF8180C Color Laser MFC Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Print Problem Go Light Flashing wont print till pushed
Sounds like its waiting for a manual feed. Check the paper you have in the tray and that the selectors on the tray are properly positioned. Once that os done, on the computer side hit the start ICON on your desktop, then control panel, then printers and faxes. Double click on your 2100 print driver to open it. Go into properties and make sure it says "automatic" for tray select. Hit the advanced key and check that it says letter or whatever paper size you have in the tray.
Verify the other settings and then save it.
That should solve your issue.
Aug 07, 2008 | HP LaserJet 2100 Printer
Brother HL-5250DN printer paper light won't go off
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
Here's the link from HP, on how to open the Fuser Cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_007.html?reg=eu&c=eu_ot&lang=en&prod=hl5250dn_all
Oct 05, 2007 | Brother HL 5250DN Laser Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Lexmark X5150 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
