Question about LG WM1812C Front Load Washer
Pump issuse we had a pump go out and a service tech came to fix it BUT i was amazed to see him do something on the front(button combination) to get it to drain when ever he wanted Can someone tell me HOW he did this?? He said he couldnt tell me cause its a shop secret !!!
  • 3 Answers
I had same issue OE error on my LG Tromm washer and the service manual was exactly what I needed.  I drained and emptied the filter about a dozen times and could not get the error to go away. I did find some junk in the filter after each of the first few times. I even powered down twice for 30 minutes. I tried the spin/soil test mode to get the drain pump going and it would not work. I ended up pulling the machine apart. I followed the service manual and I checked the resistance (ohms) across the pump motor and it was OK (it is easy to do with a simple multi-tester).  I even tested it to make sure it was OK with 120V power and it was.  However, when I removed the pump from the housing I did find some junk, wood sticks, in with the pump impeller that got past the filter.  I wondered if that could be the issue. I took the opportunity, since I removed the pump, to completely clean out the pump housing and the drain pipe.  I blew through the pipe several times and put water through it.  Lots of stench in the drain line.  Bleach took care of it.
I was disappointed that the pump was not bad since that was an easy $50 fix.  The next thing in the service manual was to check the computer board and that is expensive and hard to get.  I decided to check to see I got lucky before I messed with the computer board.  I got lucky!!! The washer works like new.  My wife immediately noticed that the clothes are coming out less wet like they did when we first got the machine a year ago.  Must have been the sticks in with the impeller.
Three loads later we are OK.  Other than this we have been very happy with the machine.  GK 4/1/08
Posted on Mar 30, 2008
    Problem Solver:
  • 9 Answers
Thank you very much for the service manual post! You have done a great service for all who own this WM. You deserve a pat on the back my friend. Thank you and best regards.
Shame on that Technician!
Posted on Feb 05, 2008
The service manual is at:
http://136.166.4.200/contents/Laundry/WM1814/WM1814_Service_Manual.pdf
1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
2. Press the Power button, while the above condition. Then buzzer will sound twice.
3. Press the Start/Pause button repeatedly to cycle through the test modes
If it's pressed 10 times, the drain pump turns on.
Posted on Dec 06, 2007
SOURCE:
Pulled tear drop locking mechanism down but keeps springing back NFW7200TW
it looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
Apr 07, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Error 21.2:13 on hp plotter t1100
Tech guys only:
Service station error..Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel) best of luck...
Jul 25, 2011 | HP Designjet T1100ps Printer
Hp design jet T770 plotter display 21.2:13 on the control panel
Tech guys only:
Jul 12, 2011 | HP Designjet T1100ps Printer
I AM GETING PROBLEM WTIH HP PLOTTER T1100, ERROR 21.2:13
Tech guys only:
Jun 11, 2011 | HP Designjet T1100ps Printer
Clean pump light appearing
Needs to be serviced as the machine is stating. if you are not a tech "guru" I would call a tech. But if you feel you can handle it. I suggest you contact a local parts supply store and they can sell you a book that will show you how to unassailable and reassemble it with ease and you will save some $$$ fixing it yourself. As this is something a my young child could fix. Nothing feels better than to fix something all by ones self. :)
Sep 21, 2010 | Whirlpool Washing Machines
Error codes on Kenmore Elite washer
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
while F09 is the water pump. It usually means something is clogging it. Take the front cover off of the washer and the water pump is located right in the middle front. Unscrew the cover to the pump and make sure there is nothing clogging it.
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Leapster won't turn on
Had the same problem. I could randomly make it turn on by some bazzarre combination of pushing buttons. Now won't do anything. Call Leapster 800 #, and thought I was getting a bunch of b.s. from a "tech" person, however IT IMMEDIATELY RESOLVED THIS PROBLEM. Remove the battery pack and batteries. Take a pencil eraser and rub/clean the contact point where each battery goes in on the tray (except the coil sides). Reinstall the batt's back in the trey. Use the eraser to do the same thing to the outside contact points on the outside edge of the tray as well as on the Leapster itself where the tray goes. Finally reinstall the the battery tray, and BINGO ! Crazy....I would have lost a bet on this "fix".
Nov 20, 2008 | LeapFrog Leapster Electronic Book:...
Hansol H950 19
Most likely the power supply, or the back-plane lamps, or the back-plane supply, or a defect on one of the processor boards is loading the supply too much, or any combinations of these are defective. You will have to have a source to try the boards to fix the monitor. I would suggest to find the authorized service rep for your monitor. They will have to service it for you. If the monitor is out of warranty, the fix will not be cheap!
Jerry G.
Apr 07, 2008 | Hansol H950 19" LCD Monitor
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
LG WM1812C Front Load Washer Logo
344 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
