Question about Network Computing Devices NC900 Network Terminal
Lg airconditoner remote contol n98
Hi there I have a lg spilt system airconditioner my remote control only works when it wants to, being usually 4 hours after aircond has been put on manually, is there some sort of aligning button on these remotes? and where is it locate? as I do recall having a similar problem with a fujitsui brand at one time and was told to realigned and it worked, batteries have all been changed, remote has not been dropped etc, any suggestions would be greatly appreicated.
  • Anonymous Nov 24, 2008
    LG Remote Controls, all 3 remote control decided to die at the same time. Replaced batteries but greeted by BLANK screen. Pressed reset knob, the screen comes to life for 2 seconds before going totally blank again.
Hi there where can i buy lg air conditioner n98.
cheers guy.
Posted on Jun 19, 2009
  • 400 Answers
Open the front grill of the indoor unit. Check on right hand side for a forced operation switch. This switch is for selecting of either manual operation or remote or auto, select remote, then try. You can also press the reset button on the remote, under the cover with a pen. Hope this helps
Posted on Mar 05, 2009
  • Anonymous Mar 12, 2009
    Second user with remote problems. Using a test meter, test each battery individually. If batteries are ok, you will have to replace the remotes.
  • Anonymous Mar 31, 2009
    There is no aligning program for the remotes. The only possibility is a bad battery (and they can be bad even when newly bought) this would need to be checked with a test meter. Or you have some carbon build up on the terminals causing a bad connection. There is a reset button which needs to be pressed with a sharp object like a pen nib. Then also make sure that the indoor unit selector switch on the right hand side under the cover is set to "remote" operation
6ya staff
SOURCE:
REMOTE CODE NEEDED FOR LG N98
These are the codes to check. 1049 1141 1132
1157 1082 1217
If you wish to get more, check these sites.http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 02, 2013 | Televison & Video
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
Oasis airconditioner broken
Unplug the unit for about 5 minutes and then plug it back in. If it still does not respond to the remote after that something has happened to the control panel. It should take 3 minutes after the unit is unplugged and then plugged in again before the compressor starts. (Self protection circuit) You can try turning off the circuit breaker and then turning it back on again also. I believe that your unit will work fine after trying these recomendations. Good luck.
Jan 12, 2010 | Heating & Cooling
Unlock LG N98 phone
type 2945#*# and a engineering menu will appear select factory reset and you will reset all your unlock codes to 0000.
Jun 01, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Dont know what symbol on remote is for heating for LG split system airconditioner
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
May 19, 2009 | LG LSC121PMA Split System Air Conditioner
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Open Questions:
See all Network Computing Devices NC900 Network Terminal Questions
Network Computing Devices NC900 Network Terminal Logo
1,179 people viewed this question
Top Network Computing Devices Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Network Computing Devices Computer and Internet Expert? Answer questions, earn points and help others
