Question about Stanton C.304
Stanton C.304 buttons
I have a Stanton C-304 DJ CD player. It's play and cue buttons are needing to be pushed harder than normal and I am wondering how to fix them. Is this just a connection problem or maybe springs under the pads are worn? HELP!
  • 1 more comment
  • Anonymous Oct 04, 2008
    I have the same problem is there any where I can get a new motherboard from
  • Jezza88 Nov 13, 2008
    Hey.. I also have the same problem with my cue button any solutions?
  • Anonymous Mar 28, 2009
    I have the same problem as well. My play and cue buttons sometimes won't respond. I can't stutter anymore with my cue buttons. So..
Contact an authorized service center for repairs.
Posted on Feb 13, 2008
Stanton c304 cd to mp3
Sorry you cant convert it to MP3 the deck only supports CD audio
Feb 04, 2013 | Stanton C.304
My cue button on my cdj 1000 mk2 kept jamming so i got some foam cleaning stuff from a dj shop and sprayed it on the cue button now it started going mad skipping traks, playing in reverse. i think that the...
cue button sticking sounds like the button on the pcu board needs replaced, I would clean all the foam stuff of if possible, as for the screen not working sound like some of your wires have come unconnected easy fixed just plug them back on to the pcu board
Mar 28, 2010 | Pioneer CDJ-1000 CD Player
I need an instruction manual for the c.304
You can download the manual by clicking the link below:
PROFESSIONAL TABLETOP CD PLAYER
Do not forget to rate the solution.
Many thanks.
Feb 28, 2009 | Stanton C.304
Stanton c.304 cdj reading disk but cant go bno futher
Check the sled motor is operating correctly.
Aug 05, 2017 | Stanton C.304
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
Stanton c303 cd turntables
the c303 has the same screen and inturnal curcit board as the 304 ans 314. the other two items you are seeing are for the other units. it was a way for stanton to save money by useing the same parts in other table top cd models.
Mar 30, 2008 | Stanton C-303 Single Top Loading CD Player...
CD Tray on one side doesn't open.
I have also had the sticking CD Tray problem with my Stanton. I disconnected the until and unplugged the separate read out control panel. I was going to strip it down, but when I plugged the power supply on it worked fine again!!!!. I wwill reconnect and see what happens!!
Dec 14, 2007 | Stanton C.501 Dual MP3 CD Player
Stanton C.304 Logo
417 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
