Question about Acer Aspire T310 PC Desktop
Computer automatically turns off - Acer Aspire T310 PC Desktop
How can I stop Skype to offer me download upgrades?
Hello, you can stop skye upgrading Automatically by turning off the Automatic updates on your Skype application. Tools > Advance Settings > Automatic Updates> turn off or on Automatic Updates
Feb 25, 2016 | SKYPE Computers & Internet
Monitor turns off automatically after every one hour.
check the power settings on the computer. change when the monitor turns off to "never".
Oct 13, 2014 | Computers & Internet
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
How to automatic torn of the computer?
the bios on you computer has changed get to your bios or setup screen when you turn on your computer hit deleter or F2 key it should promp you what to hit then in there their will be shut down options set it to when i hit button shut down save and exit. be carefull not to adjust any thing else. or you may drastically effect you system unless you know what you are doing.
Jun 08, 2009 | Medion MD-1704 PC Desktop
Can't Sign into Windows...How to do system reboot if I can't log in to windows?
Hi e_norris
Do you have either the Windows installation disk or a Recovery Disk. Some manufacturers ship the Recovery Disk with the PC others require you to create one when you first turn the computer on.
May 02, 2009 | Computers & Internet
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
When i turn my computer it automatically shutsdown
your infected with a virus. the easiest way to remove the virus is to scan your hardrive in another computer with updated antivirus.
Jan 28, 2009 | Computers & Internet
Turn off the pc automaticly
i use this to turn off my pc automatically. easy to use, lots of nice features.
http://www.ampsoft.net/utilities/WinOFF.php
Dec 19, 2008 | Acer Aspire T310 PC Desktop
Automatically rebooting computer after power failure
The bios settings turn the computer on automatically. I actually have mine set to turn on automatically in the morning before I get out of bed so it's already on when I get up. Watch what you see on your screen as you boot up the computer and do whatever it tells you to do to boot up in bios (typically by hitting the F2 or Del key). Once in bios, go to the power section. In the power setting you should see something pertaining to the modem. If you do NOT want it to power up automatically, choose the Disable option. If you DO want to power it up automatically, it will also ask for a time (day of month, hour, minute). If you set the day as 1, for example, it will power up on the 1st of the month at the time that is set. If you set the day of the month to zero (0), it will power up every day at that time.
Oct 02, 2008 | Compaq Presario SR1000T (568657) PC...
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Acer Aspire T310 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
