Question about Kenmore 54701 Dehumidifier
Constant on-off cycle
Seems to work fine but it runs for a few minutes, then shut off for a few minutes, then starts again. It continues this cycle all day. But it does collect alot of water through out the day. The manual does not say what the normal run-shut off cycle is. Thanks for any suggestions
  • 1 more comment
  • Anonymous Feb 11, 2008
    I am having the exact same problem with my unit. I tried to switch the unit over to 3hr on/off or even 6hr on/off but that function seems to not work at all. I even changed the humidity setting, but nothing seems to work. This unit is killing my electric bill because it keeps cycling on and off. I hope someone out there has a solution.
  • Mick S Apr 09, 2008
    I also am having the same problem. I also noticed that some condensation builds up around and under the digital humidity display on mine. I have had my dehumidifier for only 1.5 years. Also, I do realize that dehumidifiers are very load but this model is incredibaly loud at times, as if something is rattling!
  • Anonymous May 29, 2008
    constant on-off cycling no matter where the digital humidistat is set at. Had on instant that the compressor kept running without the cooling fan. I pulled the plug to reset the control board which got the fan running again. It wouldn't have taken long for the evaporating coil to start icing with any air.
If the unit is freezing up I suggest replacing the sensor assembly. Just replaced mine because the thermistor that is on the suction line went bad and would not send the reversing valve into defrost.
Posted on May 18, 2008
SOURCE:
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
My LG Humidifier turns on and seems to run fine for a few minutes then the present humidity % starts going up and up all the way to high then the whole thing shuts down. Of course it does not run long...
Chef, you need to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 15 minutes. While you're waiting, remove the air intake filter and clean it, if necessary. After the 15 minutes has elapsed, plug the unit in, turn the Master ON/OFF Switch to ON and set the control to Manual Operation. Lower the humidity extraction level to 32% or 35% and allow the unit to run in that mode, rather than automatic. This will give you a good indication if moisture is being extracted or not.
If it is working as it should, you can leave it in manual timed mode (normally 2 or 4 hour segments). This way, cycle On and OFF as necessary, based on any rise in humidity above 35%.
I hope this helped you solve the problem. Please let me know. Thank you.
Jun 08, 2011 | LG LHD45EL Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
We just bought our dehumidifier a week ago. It seems to run only on short cycles starting up for a couple of minutes then shutting off for a few and thencoming back on. It is very annoying and doesn't seem...
Still have the receipt? cause if its a stand alone i would say return it, short cycling could be anything from bad sensor or controls to it over heating etc., if its one on your central system, well fire your installer and call a reputable contractor.
The only thing that could cause it to short cycle it other wise would be a half opened half closed float contact switch on the internal storage for the h20 removed form the air (assuming its a prattle stand alone eat that is)
Oct 01, 2010 | Kenmore Dehumidifiers
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Kenmore 54701 Dehumidifier Logo
261 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
