Question about Kenmore 63942 Dryer
Dryer heating element
My dryer is not getting hot, im pretty sure its the heating element but i cannot access it. The back panel to my dryer appears to be bonded or welded on. It is a Web (not sure a model), we acquired it a couple years ago, i think its an industrial dryer, like from an apartment or something (no coin slots though). I just need to know how to get to the heating element so i can test it or change it
  • 3 more comments
  • Anonymous Jan 30, 2008
    need to find heating element
  • dck5 Feb 19, 2008
    model number 110.76912690
    Dryer runs but no heat
  • Anonymous Apr 25, 2008
    Same problem. Dryer runs but no heat.
  • Anonymous Apr 27, 2008
    my dryer not getting hot
  • Anonymous Apr 30, 2008
    my dryer is not getting hot
  • 291 Answers
NEED More info ...Need model # and type dryer... info u gave is misleading
Posted on Oct 09, 2007
SOURCE:
Can't find model11066922500
Hello;
My name is Peter. I am a retired field service appliance technician.
Your heating element is difficult to get at.
25438420-j5jtgwve0qxm0uckbdimcx40-4-0.jpg Unplug the dryer before installing this heating element. Remove the bottom front service panel to access and replace the heating element.
This heating element is rated at 5500 watts.
This Dryer Heating Element part #3387747
Cost: $59.00
It is located in side the housing.
You may just be plugged up with lint in your hot air distribution manifold.
Or have a bad high temperature limit switch located on the back on your hot air exhaust manifold.
25438420-j5jtgwve0qxm0uckbdimcx40-4-5.jpg Tell me what your problem is.
Feb 16, 2015 | Kenmore Dryers
My dryer is very hot to the touch
It is most likely clogged with lint, pull the lint filter and clean down in the hole it slides in. remove the vent hose and clean out the dryer and make sure the access tube going out is not clogged, remove access panel and clean anything you can see inside the dryer. Be sure to unplug the dryer before you clean out the inside. it could possibly be your high limit thermostat but usually when it goes out it burns out the element pretty quick and you have no heat. Hope this helps
Apr 13, 2014 | GE GTDX300EMWS Dryer
Dryer not heating up
Check your heating element!!!
Jun 28, 2010 | Whirlpool LER4634J Electric Dryer
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Clothes dryer
your heating element has been drooping and welded to the metal part of mount and has broken unplug the unit and replace the heating element be sure to have a knowledgeable person do. make sure to unplug the unit b4 repair is done
Sep 06, 2009 | Kenmore 62802 Electric Dryer
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
Need to change heating element on my kenmore dryer
they are pretty simple to change out.the heating element should be easy to access and once you get the old one out you simply put the new one in in its place. depending on the machine the heating element should be in the back wich means you have to take the top off the dryer to access it and then you will see what you need to do from there,its only held in but 2 or 3 screws.
Jan 08, 2009 | Kenmore 63942 Dryer
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Kenmore 63942 Dryer Logo
223 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
