Question about Sony Audio Players & Recorders
How to turn off speakers on a sony tv - Sony Audio Players & Recorders
I have a 48" Sony Bravia model KDL 4655-100 Tv has no sound
Check the audio settings to see if it the TV speakers are turned on. HDTVs allow the speakers to be turned off for setups with a home theater system.
Jul 08, 2017 | Sony Televison & Video
How can I fix the echo between my TV speakers and my dvd/blu ray player home theater speakers when watching a movie. Also, in the settings menu on the BDV E370 system do I have to select speakers only...
Easy, disable the TV speakers or turn its volume down.
http://static.highspeedbackbone.net/pdf/Sony%20BDV-E370%20Manaual.pdf
Page 36 tells you how to sync the sound to the picture but you really shouldn't have the TV speakers competing (in stereo) with the Sony. (Page 56).
A) The TV speakers are probably inferior to teh Sony's
B) When you balanced the speakers during setup there was no 'with-the-TV-speakers-on' option. The image up front would suffer by adding an unaccounted for sound source.
Aug 11, 2011 | Sony BDV-E370 Theater System
No sound is coming from the tv speakers. the tv
This TV has a function in the menu to turn off the speakers. Be sure that the setting is on.
Mar 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
No sound from tV speakers
check your speaker, use a battery 1.5vdc tap it to speaker wire if the speaker is ok you can hear a click sound as the wire touches the battery + & - .
Sep 10, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
Jul 23, 2009 | Sony KV-20V80 20" TV
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Sony kdf-60xs955 picture but no sound
Check your TV menu and see if the internal speakers are turned off. Sony opts to cut sound to the internal speakers when you have an external audio amp hooked up for sound, hopefully for obvious reasons. Most audio amp problems inside the TV will result in 9 blinks of the red power light and the TV failing to turn on. If that doesn't help, you may need to have the set repaired.
Aug 15, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv speakers
Sounds like you have a home theatre system, and you need to run rca cables from audio out of the tv to audio in on the amp, and turn the speakers off in the tv menu and set audio out to fixed or turn tv volume up all the way to get enough audio siginal.
Feb 24, 2008 | Sony BRAVIA KDL-40V3000 Television
Blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Jan 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Ilo tv
i dont think that the ilo has a sound output port:(
Oct 17, 2007 | iLO V27DMBX Television
56 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
