Question about Fisher DEIX2 Dryer
Fisher and paykel dryer not turning - Fisher DEIX2 Dryer
5 Suggested Answers
  • 1462 Answers
SOURCE: Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Posted on Nov 14, 2008
SOURCE: dryer won't turn. have cleaned & belt seems
the rollers (?) that turn the drum might need some lubrication ---- same thing happened to me and the tech removed the rollers (?? don't know the right word) and lubricated them ---- all working fine now
Posted on Sep 04, 2009
  • 10865 Answers
SOURCE: HOW TO CHANGE THE IDLER PULLEY ASSEMBLY. ON FISHER
Hello cady..... The idler pulley assembly is located at the bottom of an electric dryer, near the drum roller. Its purpose is to operate the belt that turns the roller. This action is what causes the clothes to dry in a dry tumble electric dryer.
Repairing the idler pulley assembly requires you to open the dryer up and determine whether the pulley is loose or if the tension spring has become dislodged. If the idler pulley itself looks worn or is not properly working, you may need to remove it completely and replace it with a new one. This article will discuss the how-to steps for fixing or replacing the idler pulley assembly in your electric dryer.
The only tools and parts required to do this are:
  • Screwdriver, #2 phillips and medium flat blade
  • Wrench, sockets or adjustable
  • Flashlight or Shop Light
  • Replacement Idler Pulley
  • Replacement Tension Spring
  • Step 1: Disconnect the Electric Dryer Disconnect the electric dryer by unplugging it from the outlet. You want to make sure that no electricity is flowing through the dryer while you are working on it to make sure that you do not cause any damage such as accidentally shorting the electric dryer or electrocuting yourself.
    Pull the dryer back and in position that will allow you access to the back panel in order to fix or replace the idler pulley.
    Step 2: Remove the Back Panel Remove the back panel from the electric dryer using a screwdriver. This will expose the drum roller and the idler pulley. With most electric dryer models, the idler pulley is located at the bottom near the right side of the roller. You will need a shop light or flashlight in order to see inside the electric dryer and locate the idler pulley.
    Step 3: Remove the Roller Drum In order to access the idler pulley you will need to remove the roller drum. Loosen all of the bolts or screws that holds the drum roller in place. Use a screwdriver or wrench to accomplish this. Once the drum roller has been loosened, pull the looks belt away from the drum. Try to move it out of the way to give yourself some clearance as you pul the drum out of the electric dryer.
    Step 4: Test the Idler Pulley With the drum roller cleared, you should be able to see the idler pulley and determine what the problem may be. If you push on the idler pulley, in the case where it may be working on a tension spring, it should move up and spring back into position. If not, you will need to replace the tension spring in order to restore it to its working order. Look at the condition of the idler pulley to determine if it is worn and may be in need of replacement. If this is the case, remove the idler pulley and replace it. Place the drum roller into position and belt and close the back panel.
    Joe
    Thanks for choosing Fixya!
    Posted on Jan 20, 2011
    • 154 Answers
    SOURCE: I have a Fisher Paykel dryer that is squeaking
    There is a drum bearing kit which could have failed or also the belt drive pulleys could be squeeking.
    Best to get them replaced.
    Can't oil or grease them.
    Ash
    Posted on Sep 11, 2011
    Where can I get a new belt for my ED54K Fisher and Paykel Dryer?
    www.coolblueworld.com is Fisher Paykel's website. You should be able to find what you need once your there.
    May 19, 2012 | Fisher and Paykel Dryers
    How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
    sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
    http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
    Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
    Looking for a parts list for a Fisher Paykel DEIX2 dryers
    DEIX2 - one of the heat coils remains hot after dryer stops. I can see that it is still red (hot) after dryer is turned off. I need to unplug dryer for it to go off.
    Oct 14, 2010 | Fisher and Paykel DEIX2 Electric Dryer
    Auto dry not cutting off when clothes are dry
    Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
    Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
    My dryer is a top loading Fisher and Paykel and it has started squeaking.
    It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
    Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
    Squeal when dryer turning
    The problem is that your dryer needs a new drum bearing.
    Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
    Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
    Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
    How to replace belt on Fisher Paykel Electric Dryer
    Yes hello, I just wanted to know what belt a fisher and paykel dry model# DGO5-USO take? Thanx!
    May 18, 2008 | Fisher and Paykel DE06 Electric Dryer
    Fisher DEIX2 Dryer Logo
    19 people viewed this question
    Top Fisher Dryers Experts
    Tim Whalen
    paul
    paul
    Tom Chichester
    Are you a Fisher Dryer Expert? Answer questions, earn points and help others
