Every Paper roll up at registration in ir 3300
    Problem Solver:
  • 9 Answers
Drum cartridge might be seized up. check drum for partial image. If none exists, drum is not rotating.
Posted on Nov 21, 2013
  • 57 Answers
SOURCE: black bande IR 3300
Most probably you need to replace the drum unit. If you have any idea what was the copy count when the drum was last replaced and since then around 50000 prints are done, new drum is needed.
Posted on Jun 12, 2008
ctf1800
  • 4402 Answers
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Posted on Sep 03, 2008
SOURCE: ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Posted on Feb 10, 2009
  • 7 Answers
SOURCE: how to solove thiis problam ir 3300 E000602-0003
Just entered in service mode by press add. functon button then 2&8 together and add. functon button, in service mode entered in Copier then function then clear and touch ok tab in touch screen. restart ur machine error code should be cleared.
or run harddisk scanning mode by holding 1 & 9 buttons then switch ON machine. it will take one & half hour.
if still there is a problem then you need to change your machines HDD.
Posted on Jul 17, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Mar 04, 2015 | Canon Ir 3300 Black & White Copier
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
How can i fix the dark line in ir 3300 appearing on paper when printing?
If you have pulled the paper while printing, you might need to re-calibrate the drum. Go to your printer settings and re-calibrate it.
Aug 04, 2014 | Canon IR 3300 Digital Copier
Canon ir 3300
Try the following:
1) check for toner levels (may need new cartridge)
2) check for paper on the tray
3) try printing a copy from that device.
Dec 30, 2013 | Office Equipment & Supplies
Ir 3300 paper jam
Sep 03, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
21 people viewed this question
jasbo
jasbo
