Question about Cosco Baby Gear
Alpha omega elite car seat manual - Cosco Baby Gear
quare3
  • 48 Answers
SOURCE: Converting to a Booster Seat.
Better yet, please use this manual for clear instructions and dont forget to leave a rating for me. Thanks!!!
http://www.coscojuvenile.com/instructions.asp
Posted on Jan 25, 2008
  • 6 Answers
SOURCE: Cosco Alpha Omega Elite car seat
Manual is available at the manufacturer's website
http://www.coscojuvenile.com/instructions/
Posted on May 01, 2008
  • 25 Answers
SOURCE: Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Posted on Feb 19, 2009
SOURCE: REMOVING COVER COSCO ALPHA OMEGA ELITE
Remove the base by pushing the metal rod on the bottom through the side that is open. This will allow you to remove the straps that hold the covering in place.
Posted on Feb 12, 2010
ozark333
  • 396 Answers
SOURCE: Looking for an online car seat manual for my Alpha
Go to the site thru the link below. Put in your model number and date of manufacture.
It will give you the manual.
Alpha Omega Lookup
Posted on Mar 31, 2011
Manual car seat model 22456 CAB
hello
i can not install my new alpha omega elite car seat model 22456.CAB please guide how can do it ?
Jan 08, 2012 | Safety 1st Alpha Omega Elite 3in1...
Don't know how to connect for rear facing
Here is a link with instructions to follow to install the seat in a rearward facing position. Good luck.http://www.ehow.com/how_7624391_instructions-cosco-alpha-omega-elite.html
Jul 25, 2011 | Cosco Alpha Omega Elite 5-Point 22-155
Looking for an online car seat manual for my Alpha Omega Elite (2007). Cannot find with general searches. Any suggestiions?
Alpha Omega Lookup
Mar 29, 2011 | Cosco Alpha Omega Elite - Hammer Print
How to remove base off of Safety 1st Alpha Luxe car seat?
How do you get the base off of the saftey 1st alpha omega elite car seat ?
Sep 28, 2010 | Safety 1st Alpha Omega Elite 22456 TTN...
Need a manual for cosco alpha omega car seat
You can input your seat's model number and date of manufacture from the label on the seat itself at Cosco's website to download the instruction manual at http://www.coscojuvenile.com/instructions/
Sep 05, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
How to change the Safety 1st "Alpha Omega Elite" to a booster
To change it into a belt positioning booster seat, you remove the harness straps completely and use the positioning clips on the side of the carseat (up by the head) to position the automobile's seat belt to the appropriate position.
Apr 18, 2010 | Safety 1st Alpha Omega Elite 22456 TTN...
Mar 19, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Instruction Manual
You can go to this site for that information. You'll need the model number and manufacture date, but you should be able to find those pretty easily on the seat.
Nov 22, 2007 | Cosco Alpha Omega Elite - Hammer Print
I have the cosco alpha omega elite 22-155 and i need a new cover
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
  • Check out the recall notices and make sure your seat is not listed.
  • Register your car seat so that you are informed of any future recalls.
We have taken our car booster seat apart and ran the cover through the laundry. We used the delicate cycle and COLD water. We also soaked it overnight. This resulted in a very clean cover. MAKE SURE you take several good quality photos of it so that you can get it back together again. Online manuals do not seem to exist.
Nov 08, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Baby Gear Logo
51 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
