Question about Philips HDD070 MP3 Player
Flickering screen. All I get out of our HD070 is a flickering screen, tryed resets and battery charges, any suggestions? 5dad
I've had 2 and 1 did that to me i switched the battery-and that fixed it but then it wouldnt transfer any more songs so ! At the top right theres a phillips head screw-remove that and pull it out just a little then turn it as theres a little catch in the middle of it,if you try to pull it straight out it may break so turn it while you do so it will come loose just have to kinda twist it or you can slide a credit card down the side til you feel it then it will open/look the 2 i have dont work no more for the cost of the battery ill send it to you say 10 $ and no i wont send it to first then etc... but if it was me i would just get a different model like an apple
Posted on Oct 09, 2007
SOURCE:
My coby kyros tablet touch doesnt work
Try to reset the unit. the battery may be faulty.
Dec 10, 2013 | Coby Kyros MID7012-4G 7" Tablet, Telechips...
Laptop screen flickering when battery charging
The power supply adapter may not be delivering enough power when you run it and trying to charge the battery at the same time. The only way to find out is sub another power supply.
Jun 19, 2012 | Toshiba (M305-S4910) PC Notebook
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
Reset button stuck
Firmware upgrade to resolve permanently (Creative website)
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 29, 2008 | Creative Labs ZEN V Plus MP3 Player
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Ipaq 2215 will not boot
how do you know that new battery is anygood
many are old sat on self for years and no good now.
this device is 14years old now. 2003 reviews show it.
so what do you do with it?
games?
diary?
my guess integrated WiFi , using that? with home router?
can it run Whatsap or Skype?
maybe battery charging is failing?
why not just take the cash to fix this old PDA
and buy a used, smart phone, some are like $20 now .
old and slow and small but miles ahead of any PDC.
just thought.
Apr 01, 2017 | HP FA162A for iPAQ 2215/4155 Keyboard
Philips HDD070  MP3 Player Logo
47 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
