Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Pressure washer runs then stops - Briggs & Stratton Prosumer 20324 Gas Pressure Washer
    New Friend:
Turn your fuel switch on.
Posted on Aug 30, 2016
Is there a lubricant I can use to unstick frozen pressure washer pump?
If pressure washer got frozen over the winter, the pump is bad. replace! Use winter pump protector during winter storage!
Mar 29, 2016 | Honda 2500 PSI Gas Pressure Washer
Why won't my pressure washer pump?
If its turning and you have no water or pressure is there a hose with a valve
a water seal that are connected the wrong way around ?
if not , the intake basketfilter on water drain hose.
if there is water and all iss clean and the motor runs no water then there is lime inside the valves fixed Liming most times its not running for a long time and has possible standing quite a long time been under a warm temperature in cellar if thats also not the answer then there should be a bypass connection thats not working because of lime thats actuates a microswitch (modern pressure washers an auto-stop for the motor if there is water demand only then the motor runs and by old pressure wachersthe bypass is only to have a microcirculation without stopping the motor to run but works by demand , most times there is a cuff-kit necessary but be aware it could be a bit expensive for budget models pressure washers that its relating not worth a repair . if a new pressure washer is cheep. it depends on the user and his priority on which he used the machine.
Nov 13, 2015 | Garden
Power boss pressure washer stops when trigger is released
The unloader on yoru pump is bad.. Pressure washer parts catalog quick links Pressure Washers High Pressure... go here with your model number on your pump and they can guide you to your new unloader. Good luck
Apr 17, 2014 | Powerboss 20309 3,000 PSI 2.5 GPM Gas...
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
I have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
Feb 28, 2010 | Karcher PSI Electric Pressure Washer
Washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
Sep 02, 2009 | Garden
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
145 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
