Question about Canon ZR100 Mini DV Digital Camcorder
REMOVE THE CASSETTE message
I purchased a Canon ZR 100 AND a Canon ZR 300 at the same time (for Me and my son) at Christmas 2005. The two are virtually identical except that one has a built in still camera. Both worked flawlessly for about 18 months. Neither was abused, dropped, damaged or used excessively. Both have (almost simultaneously) started rejecting mini DV cassettes of all varieties and brand names. If a tape is inserted it says "REMOVE THE CASSETTE" and it won't allow the compartment to accept the tape and close. It seems awfully strange to me that BOTH started doing this at the same time for no apparent reason. Both have been well cared for. I have now discovered on this web site that quite a few others have experienced this same problem on ZR100's for no apparent reason. Can anyone say "RECALL"?
  • 13 more comments
  • Lickzee Nov 05, 2007
    I have the same problem..every time the cassette compartment come up there is five beep. when i put in a tape it eject automatically..
  • jackbenimble Nov 09, 2007
    Yes exactly the same problem on a Canon MV800i. After a bit over 18 months the DV cassette won't go in. It beeps 5 times and pops open and says remove the cassette.
  • Anonymous Nov 09, 2007
    Yes, I have the exact same problem with my camcorder. Does anyone know a solution?
  • lconway20 Nov 24, 2007
    My Canon ZR100 displays the "remove cassette" message also. It is nearly 2 years old with light use and has never been dropped or left in a situation that would allow condensation to develop. I believe Canon has a problem with these cameras and should step up and fix them for us!
  • cloray Dec 15, 2007
    I have the same problem, however once I was able to load the cassette, I cannot remove it.
  • Anonymous Dec 17, 2007
    Is ther a recall on this ZR 10
    Hey Man I paid $600 a few years ago this is not cool.
    Canon should eat it.
  • Hope68 Dec 17, 2007
  • Anonymous Sep 14, 2008
    I as well have the same video camera and also
    have this problem. For sure I think Canon should
    come good for the expenses to fix the problem.
    I do not think this is a coincidence.
    Trisha
  • Anonymous Oct 24, 2008
    I had not used my camcorder very much, but I would say after about a year or so, it started spitting out the cassettes. I have taken very good care of it, so it is of no fault of my own.
  • vegasgeek Dec 10, 2008
    Took my camcorder on a zipline adventure and it totally let me down. Very disappointed in Canon for producing such an unreliable product!
  • kari32870 Dec 17, 2008
    I have the same exact problem with my Canon ZR300. I recieved the message- Remove Cassette- and now it no longer excepts the tapes. it will not allow the door to close with cassette in place. i have had my Canon for about 18 months also.
  • Anonymous Jan 17, 2009
    yes, could you please upload it to youtube?
  • spro512 Jan 18, 2009
    got the same proble the pal version XM2 canon . the cam few months old allmost new but cant revind the tapes after 30 sec it say remove the cassette. u tryed sony panasonic and maxell cassetes the same resoult pls help
  • Anonymous May 06, 2009
    I have the same problem with my canon mv830. please does anyone know how to solve it!!!
  • Anonymous May 16, 2009
    "remove cassette" problem on my new hv30 camcorder :X
  • 3 Answers
Perhaps this will help some.
I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation appears to apply to you, try the following, and make sure that in the future you don't fully rewind your tapes!
Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, locate the notch between the two spools (the "wheels") near the top, that is, opposite the side where the tape is exposed. The notch will have a spring-loaded slider inside which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.)
Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Posted on Jun 11, 2009
If someone need know how fix the problem "Remove the cassette", let me know. I try to upload the video to youtube
Posted on Dec 07, 2008
  • 3 Answers
They all use the same transport mechanism, which is flawed. I sent mine back under warranty as this is a well-known issue with certain Canon camcorders from their cheapest ones to their most expensive ones (like the GL2). It is a common error. Do a search on Google for "Canon Remove the cassette" and you'll see lots of entries.
See http://mysite.verizon.net/resohb20/
Posted on Dec 05, 2007
    New Friend:
  • 3 Answers
Hi!
I have two Canon Mv5i miniDV camcorders. They both developed this problem. I sent one to Canon for repair. They charged me a fortune to replace the entire tape drive mechanism, yet 6 months later I got the problem back. Very disappointed by Canon. And remind you Mv5 costed over $1400 new!!!
Posted on Apr 11, 2012
SOURCE:
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to [email protected]
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
I have a canon zr 100 camcorder. the problem i am having is that it keeps ejecting a cassette when i am trying to load a cassette.it will close without a cassette in the compartment.please let me know what...
Usually caused by a nearly dead battery or a bad cassette. However...before proceeding, make sure there are no foreign objects, such as filament paper that cassettes are wrapped, in cassette slot.
1) make sure battery is fully charged
2) try using a new cassette
Jul 11, 2009 | Video Cameras
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Canon zr200 cassette loading
reading other threads here the soloution that works, yes for real, slap it on the tape side (closed) a few times then try to reload the tape, if it doesn't work the first time, close it and try slaping a few more times. I had to do it a few times but it does work.
Mar 28, 2008 | Canon ZR200 Mini DV Digital Camcorder
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? [email protected]
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
1,967 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
