Question about Canon imagePROGRAF IPF605 Printer
How to disable ink on canon ipf605 printer - Canon imagePROGRAF IPF605 Printer
3 Suggested Answers
celibytes
  • 70 Answers
SOURCE: Low ink disables scanner
you can replace the cartridge if you want,but if you want to disable the ink level monitoring,you have to follow the on screen instruction from canon that will pop up on your screen,until you get the message "press stop/reset button for 5 seconds".
Posted on Sep 10, 2009
  • 191 Answers
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
Posted on Sep 22, 2009
How to update canon ipf605 firmware through download mode
To enter DOWNLOAD MODE the machine has to be switched OFF. While the machine is off, hold down the stop button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in DOWNLOAD MODE.
then later you can use L printer services tools to update or go to canon website select support & download select you model machine and windows OS find firmware update tools .after install it he will automatic detect you printer then he will go internet online download the new firmware install it.
please never do any printing when upgrading firmware. After finish it will automatic restart machine.
Nov 17, 2016 | Canon imagePROGRAF IPF605 Printer
Canon ipf605 printer will not enter service mode, how do i correct it
try this method mode.
To enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
HOW TO RESET ERROR E161-403E
  • To enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..if ok means printhead problem need replace.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
May 03, 2016 | Canon imagePROGRAF IPF605 Printer
Error code E161-403E
The instructions are here - Canon imagePROGRAF iPF605 User Manual Replacing The Printhead When To.... You can also download the whole manual there, but be warned it is *huge*
Aug 05, 2014 | Canon imagePROGRAF IPF605 InkJet Plotter...
How to enter service mode in canon ipf605
Ansewer
Enter the Service mode following the procedure below.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Information] button.
* Keep pressing the above buttons until "Initializing" appears on the display.
3) "S" is displayed in the upper right corner of the display showing the version.
4) After display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
Canon ipf605 ink ctridge refilling is possible?
It may be possible but not recommended because you could cause many problems with the machine and they will get expensive best to just pay for Canon inks.
Dec 01, 2013 | Canon imagePROGRAF IPF605 Printer
Cant clear Error Code E161-403E on canon iPF605
to enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
Dec 06, 2011 | Canon imagePROGRAF IPF605 InkJet Plotter...
Canon imagePROGRAF IPF605 Printer Logo
213 people viewed this question
old marine
old marine
