Question about Nokia 5300 Grey Cellular Phone
PROBLEM WITH THE NOKIA 5300 XPRESS MUSIC
Hey Guys hope you can assist, I have the Nokia 5300 x-press music, I went to change the front and rear cover on the phone as the old one had marks, as I changed the cover there is a small gold looking little resistor thing and also a black small rubber rubber that goes on top of it (THIS IS ON THE FRONT COVER OF THE PHONE)I changed these and put them on the new cover as well, now all of a sudden I cannot be heard if I call someone , I can hear the person on the other end but they cannot hear me, I have tried making a call without any of the covers on and it is the same thing, so I am not to sure what I have done, please help if you can.
  • 13 more comments
  • Anonymous Nov 23, 2007
    The same sound problem just started on my Nokia 5300 tonight. Only I haven't opened any of its hardware, haven't dropped it, and haven't gotten it wet. My call recipients hear only static. I hear them perfectly.
  • Anonymous Nov 30, 2007
    after changing cover the mic stop working
  • stevepb Dec 22, 2007
    The screen is EASILY replaced for $20 bucks or less. Just go to ebay, and search nokia 5300 lcd screen. I got a replacement and it took me 2 minutes to replace a cracked screen!! I was sooo happy I did not need a new phone.
    Steve
  • melodyky Mar 12, 2008
    I PURCHASED A NEW FACE PLATE FOR MY PHONE WHEN I CHANGED IT IT HAD A LITTLE RUBBER RESISTOR LOOKING PIECE IN THE LOWER PART OF THE OLD FACE PLATE SO I PUT IT IN THE NEW COVER NOW NO ONE CAN HEAR ME I CAN HEAR THEM BUT THEY CANNOT HEAR ME.
  • chriza Apr 30, 2008
    i have the same problem...where is the mic????plz help!
  • krayzierj May 09, 2008
    I have the same problem too. i hear voices at the other line but on the other line they dont hear me. even if i am in a video mode when i recod a video their is no voice on the video. Can u help me wiht my problem? tnx
  • tammyz27 May 11, 2008
    my phone has no bars. when i try to make a call it says i have no network connection. the sim card works in other phones just not my nokia 5300 xpress music phone. it really sucks and i would appreciate being enlightened if anyone can help..
  • Solaris Jul 02, 2008
    Hi!
    I have a same problem but i clean microphone (right/down of top case) -please carefull the microphone is onboard- and replace the orginal 5300's case instead not standard case and reset the phone. My problem is solved.
  • Anonymous Jul 23, 2008
    i had the same problem its the mic i had to order a new one
  • Anonymous Aug 14, 2008
    hey i got in the pool for like 10 seconds and got out cuz my phone was in my pocket and i left it driyng for a few weeks and it work fine but my battery didnt charge so i got a new one and a new memory cuz all my music , pics, videos, ect.... got errased so now it works but my phone wont charge and now i cant turn it on.
  • lulucasm32 Aug 14, 2008
    my phone got wet and i left it drying for almost a month and now i got a new battery and memory for my phone cuz all my contacts, music, pics. etc.... so my phone works fine but my phone won't charge i dont know if i should get a new charger but i just need help if you have any advice please email me at [email protected] thanks
  • Troiboi123 Aug 25, 2008
    my 5300 wont charge.i tried two different chargers but it still wont work.do i need to get a new battery or a different charger.it use to charge but i had to hold it a certain way.any help?
  • Anonymous Oct 22, 2008
    Hi all ,
    I have same problem. If you found solution then let me know.
  • kentravels Dec 09, 2008
    my 5300 had a crack on the lower right. same thing changed front and rear cover and now i have the problem.
    I can hear my voice going through the microphone to my own speaker, but when I call someone it's not transmitting my voice to them.
  • desidude Feb 02, 2009
    I can not be heard neither I can hear. The loud speaker works.
Aol videos has a repair solution for the microphone,,,,thier is a small connector on the faceplate itself that you need to take off and put on the new faceplate.it is where the mic is located,it looks like a small black rubber with two brass pins in it..good luck!
Posted on Feb 22, 2008
Well, i just discover the same problem when i got a new cover for my 5300. I fixed it by carefully taking off the mic out of my old cover. Take a toothpick and poke it through the front hole of the cover and it should pop right out. be careful to not touch the coils or it is ruined. Then put it in your new cover and it should work. I hope this helps out cause it cost $15 for a rubber mic.
Posted on Aug 02, 2008
You guys forgot to put the mic on...lol
Posted on Mar 12, 2008
Okay. I just turned off my phone for 30 minutes, turned it back on, and now the sound is fine. Could the microphone be sensitive to cold weather? I hope this isn't a glitch with the 5300. So far this is the only place on the Web where I've heard of this problem with this phone.
Posted on Nov 23, 2007
  • 91 Answers
You´ve messed up the microphone, I have no other solution for you than getting the phone repaired be a pro.
Take it to your nearest Nokia Service-Center and have them take a look at it.
DIY-repairs sometimes go wrong.
Posted on Oct 10, 2007
    New Friend:
My 5300 only detect network on a sim and it didn't display the other sims network... Pls help
Posted on Mar 14, 2011
    New Friend:
For the microphone buy a microphone 5300 nokia on ebay for 1.99 and replace it sits next to the keyboard on the underside of the front cover. for the charging problem buy a damaged 5300 and change the back mother board two screws and two clips and a ribbon to remove.
Posted on Oct 20, 2010
Ughh my 5300 is tore up. It has microphone problems and now randomly shuts off and I have to remove the back cover and take out the battery and put it back in for it to turn on. All the settings have magically restored themselves and I lost all my pictures. this phone stinks
Posted on Apr 21, 2008
One of my old phones had the same problem where I could hear the other person talking but they couldn't hear me. To fix it, I also had to shut my phone off for awhile and then turn it back on so it's not just with the Nokia 5200, which I now have.
Posted on Feb 21, 2008
Make sure you didn't loose the two little coil springs that came off with the outside cover. They are suppose to be in the two little holes. That is what makes the connection in the microphone.
Posted on Dec 21, 2007
SOURCE:
Restriction code
Are you sure that your Nokia 5300 Xpress Music is completely unlocked from network restriction? If you have unlocked it, you can definitely use any other GSM SIM card with it. If you are not able to access any SIM card with it, it seems to be you have made some mistake in unlocking. The safest and easiest way to unlock a Nokia 5300 Xpress Music is using unlock code. You can get the accurate unlock code for a Nokia 5300 Xpress Music from OnlineGSMUnlock.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5300 XPRESSMUSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5300 XPRESSMUSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5300 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5300 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5300 XPRESSMUSIC
Aug 30, 2014 | Nokia 5300 XpressMusic
Music player file not found for nokia 3110
this is software problem flashing 100% ok bro
Jun 01, 2010 | Nokia 3110 Cellular Phone
I was listening to some music on my fone then the screen just went blank!! i turned the phone on and off to see if anything would happen but it didnt every time i turn the phone on it has a blank screen...
Its manufacturing defect. If your phone is covered under warranty then you can get a new phone because it is covered under warranty. But if your phone is old and not covered by warranty then you have to change its LCD screen.
Mar 04, 2009 | Nokia N95 Cellular Phone
I forgot my security code
there is a hard rest for all nokia S60 phones that will sercurity code.
press and hold 3, * and the green call button, hold these down and power up the phone, keep holding until you hear the nokia tune and your phone will be retuned to factory settings.
Make sure you backup you phone first as this will wipe the phone memory but will leave the memory card data intact.
Jan 07, 2009 | Nokia 5300 Grey Cellular Phone
PROLEM IN TRANSFERING MUSIC FROM PC TO CELL
I had some problems at first but don't think i had this. Anyway, there are at least 3 different ways to copy music that I can think of. Nokia Music Manager (tho this can be slow), Copy from 'My music' in Xp (Music in Vista) or copy from Windows Media Player. You could also put your phone into Data Transfer mode rather than Nokia Mode and transfer the files in file manager. Hope this helps. By the way, if anyone wants to upgrade to a 5310, it should be a great little phone similar to 5300 but slim but I've had problems with it cutting out during playback and re-booting. My old 5300 which my friend now has, the speaker has just bust! I will be getting Sony Erricsson next!
Dec 28, 2007 | Nokia 5300 Grey Cellular Phone
How can i chang the front cover of my 5300 cell phone?
It just pops off like the other covers. But be Very careful. Part of the microphone comes off with the cover. You will have to remove it from the old cover and put it in the new one. Also there are two very small coil springs (and I mean Small!) that are in the part of the microphone that comes off with the cover. If you loose them people won't be able to hear you. So be cautious of this.
Dec 20, 2007 | Nokia 5300 Grey Cellular Phone
How do I change the front cover on my Nokia 5300 phone?
put ur nail were the play button is thn go round the fone till it comes off
Oct 27, 2007 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Music Xpress faceplate with hex tool.
patti1010 -
DaveRaYFTA - go to nokia.com and download the instructions manual.
Oct 26, 2007 | Nokia 6288 Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
2,540 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
