Question about Canon PowerShot A610 Digital Camera
Canon digital camera powershot no lcd - Canon PowerShot A610 Digital Camera
SOURCE: canon powershot g3
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Posted on Jan 31, 2008
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
zohail
  • 1223 Answers
SOURCE: Lost my Canon PowerShot G9 Digital Camera Solution CD-ROM
All related software for ur camera See drivers and download section
Here
Pls rate me WELL !
Posted on May 18, 2009
t00nz
  • 4738 Answers
SOURCE: Digital Camera CANON PowerShot A410-No VOICE Record
I'm sorry to tell you, but the PowerShot A410 model does not have a microphone to record voice. Of all the A400 models, only the A410 and A420 were made this way. For some unknown reason, Canon decided to not include micorphones wiith these two cameras, thus they can only record video, but no voice.
Posted on Dec 25, 2009
hmerchant110
  • 7191 Answers
SOURCE: just need user manual of my powershot A80 digital camera help pls
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 29, 2010
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
My 10 second timer function doesn't work after I dropped my camera.
Canon PowerShot SX120 IS 10MP Digital Camera - Sam's ...
www.samsclub.com > ... > Cameras > Point & Shoot Cameras
Sam's ClubCanon PowerShot SX120 IS 10MP Digital Camera .... 2-sec./10-sec. delay, Custom*, Face Self-Timer** * Shooting start time (0-10 sec. ... 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, ..... just because it has a cover, doesn't mean it didn't work open in your pocket, or little fingers ...
Canon PowerShot SX120 IS Digital Camera 3.0 inch LCD ...
Jan 01, 2016 | Canon PowerShot SX120 IS Digital Camera
White/purpule screen appearing on LCD in canon digital camera powershot A2000 IS
Probably factory defective sensor. Canon had a recall about that a few years ago. Affected other brands too. Canon repaired my Powershot A95 free of charge when that happened, even though warranty had expired.
Sep 07, 2011 | Canon PowerShot A530 Digital Camera
The LCD on my canon powershot S1 IS does not work
Its known problem of ccd imager in Canon S1 IS camera and Canon will repair it free of cost.
Click and find Canon CCD Imager Advisory at right side of page for details.
Jul 02, 2009 | Canon PowerShot S1 IS Digital Camera
Nothing displays in LCD screen, canon powershot S400 digital ELPH
Sounds like your LCD might have gone bad. The LCD might cost more than the camera costs, but there are a few places on eBay that you can buy a repair and replacement service from for pretty cheap.
Nov 01, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A610 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
