Question about Logitech R-20 Computer Speakers
Subwoofer not working on computer - Logitech R-20 Computer Speakers
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
Can not get subwoofer z-340 to work with i3 laptop. Speakers work, but not subwoofer
Ensure it is connected according to the manual and plugged into a wall outlet for power. The small speakers might work just being plugged into the computer but the subwoofer requires a much higher voltage to run.
Sep 28, 2013 | Logitech Z-340 Computer Speakers
The subwoofer isnt working but speakers are
You mean the right and left satellite speakers are working but the subwoofer is not. Try to adjust the bass control of the subwoofer at the back. Set it to full.
Dec 23, 2009 | Boston Acoustics BA745 Computer Speakers
Subwoofer problem
the wires inside may be the problem, or sometimes it is from it`s mainboard, ask an electrician to take a look inside
Oct 29, 2009 | Creative Labs Creative SBS 380 2.1...
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Jun 03, 2009 | Logitech R-20 Computer Speakers
Built in subwoofer not working
check for the volume of the subwoofer
see the voume sttings
Mar 28, 2009 | HP Audio Players & Recorders
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
Logitech R-20 Computer Speakers Logo
37 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
