Question about Dell 1600n All-In-One Laser Printer
No paper error
I receive the message NO paper despite having the paper tray full and installed.
  • 7 more comments
  • bigjon Nov 07, 2007
    [No Paper]
    Add Paper
    ...even though paper is full in both trays.
  • Anonymous Nov 08, 2007
    I have the same problem.  I can get the printer to print again if I turn off the printer and unplu everything and resett it but in a couple days the problem comes back.  What is the deal?
  • sdfz Nov 14, 2007
    Same here. I already only use the "all in one" for printing because of the unreliable scanner (sends blank faxes, very helpful...). Now this.
  • tiger0516 Jan 07, 2008
    Which lever? Could you please clarify? Thanks
    http://www.ebizcamp.com/1600n-no-paper-1...
    http://www.ebizcamp.com/1600n-no-paper-2...
  • Anonymous Jan 14, 2008
    No Paper error with tray full
  • Anonymous Jan 23, 2008
    Exactly the same problem. It's very frustrating. I've been shutting it off, but I don't always have the time for that. I'll try your fix next time. Also this is my second Dell 1600n and when I plugged in the second one, PaperPort freaked out and despite reinstalling the software several times, it still is all messed up.
  • rudy1223 Jan 30, 2008
    I am having the same problem. I am not sure which plastic piece is being referred. Thanks for the help.
  • Ephraim30 May 12, 2008
    same problem
  • segrayer Dec 08, 2008
    I get an out of paper error when there is plenty of paper. Tried turning off the printer but error persisited
  • 4 Answers
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Posted on Nov 29, 2007
It could be a Paper Size issue or a Paper source issue, sometimes the document you are printing will have a different page set up. Try placing paper in the manual feeder or change the page set up of the document
Posted on Jul 14, 2009
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I continue to receive "paper too narrow. load with wider paper" message despite using 8 1/2 x 11" paper. This was not an issue I've ever had before and am using the same size (standard) paper as I always...
Check the Paper Size Settings.
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
If you have a problem just reply on us.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
No Paper Message- when the tray if full
When removing the tray - turn off printer -
insert try with paper - turn on printer -
you should notice the blue paper meter moving. fixed
Oct 20, 2008 | Brother MFC-8460N All-In-One Printer
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Dell 1600n All-In-One Laser Printer Logo
1,513 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
