Question about Fellowes DM8C Cross-Cut Shredder
My fellowes shredder will.only turn on in reverse
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 291 Answers
SOURCE: Fellows DM8C shredder that runs continuously
click this link directly to clean thje sensor as per the system,
http://fellowes.com/fellowes/materials/documents/DM12C_Cleaninfo.pdf
and click this link directly to solve anyother problem which is coming in the machine
http://fellowes.com/fellowes/site/support/support_troubleshooting.aspx#dm12c
Problem: Shredder runs continuously when switch is in AUTO (l) position
Solution:
Move the power switch to the OFF (O) position and unplug the shredder. Use a Q-Tip/cotton swab (from the top of the unit) to clear the paper blockage at the auto-start sensor (center) location. Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage.
Problem: What if My Shredder is jammed
Solution:
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
MANY A TIME THE PROBLEM IS MAIN BOARD OF THE SHEDDER UNIT GONE FAULTY ,IF THAT IS THE CASE THEN IT NEEDS REPARING FROM PROFESSIONAL TECHNICIAN.
please do rate the solution.thank you for using fixya.keep updated.
thanks.
Posted on Apr 12, 2009
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
squipps
  • 204 Answers
SOURCE: our fellowes shredder runs in reverse
Sounds like the rocker switch is turned around. I would just change it or re lable the switch
Posted on Dec 18, 2009
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Shredder does not turn off
You need to clean the paper feed sensors. You can call Fellowes customer service at 1-800-945-4545
Feb 11, 2008 | Fellowes Powershred P-55C Light-Duty...
Fellowes DM8C Cross-Cut Shredder Logo
32 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
steve morris
steve morris
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
