Schema onkyo a-9155 - Audio Players & Recorders
I plugged in a cable from my TV's headphone socket to my Onkyo 9155 amp while the amp was switched on. It made a loud click as hasn't worked since. What could the problem/solution be?
Plugging in the cable from the TV headphone socket to the amp is not a problem, one needs to make sure that the volume from the TV is turned down and then slowly turned up. If both TV and Amp volumes were too high this could of blown the output stage or maybe just a fuse. If you are getting no power or it does power up but no sound, then i suggest it is checked by qualified technician. If you want to do further test please message me back and i will see if i can help.
Feb 17, 2015 | Onkyo Audio Players & Recorders
Model 9155 display says: "UPS
bypass is not available because your input is going in one phase rotation and the bypass is going another. Both input and bypass needs to be a clockwise rotation. A cheap phase rotation meter will fix this. Call me at Gruber Power Services for free tech. support 800-658-5883 x256 ask for Eric
Aug 23, 2011 | Eaton Powerware 9155 UPS UPS System
We want to know the part no and datasheet of the lcd display used in 9155 powerware ups, 10 kva , 3 - in 1 out. We found from the part the following details: VBEST VDM-000130 , ES01 thanks and await
Eaton does not publish that type information on their website but here is the product page: www.eaton.com/9155 You can contact them directly for service and replacement parts:
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail (Hardware): LargeUPSTS@Eaton.com
Mar 14, 2011 | Powerware 9155 Model 10 (K410110000) UPS...
We have alarm led red on, in UPS Power ware 9155 12kva, please your help.
a red alarm on a ups normally means the batteries are dead. you will need to order and replace the batteries in the UPS.
Thanks
Mar 11, 2010 | Powerware 9155 Model 12 (K412110000) UPS...
Sir,How to write the code in visual basic to create database in oracle? please help me.
Hi
I guess when you say database thats what you mean and not schema . the terms of database and schema are different from one db to another .
Usually you don't create database from vb or other language, although i guess you can do that .
follow the commnds in the folowing link you just have to embed them in your vb code .
good luck
Mar 03, 2009 | Onkyo TX-SR705 Receiver
Schema
In AD, the schema is the list of "properties", or attributes of each item an AD "object".
There are different object types - user, computer, group, and so on. Some properties exist for all objects - "name", "create date", etc. Other properties only make sense for certain objects - a user has a "phone number", but a computer object does not.
So the schema is a list that says what "object types" are defined, what "properties or attributes" are defined, and which properties are valid for which objects.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
 Grubhead
Grubhead
