Home | Rinnai | Desa Vent-Free Infrared Gas Heater: Ven... | No gas coming out of the...
Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater
Problem for Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free...
No gas coming out of the pilot line.
By jyoung6 on May 06, 2009
Disconnected the pilot line, pushed the pilot gas button and no gas coming out of the line. Yes the gas is turned on and will come out of the connection prior to the heater.
Solution #1
posted on May 08, 2009
Not Rated)
hvac teacher
Rank: Guru
Rating: 91%, 51 votes
Removing the pilot tube. Remove the pilot assembly. Blow through the tube. It should be clear. If it is then your problem is in the pilot assembly. Where the brass fitting connects into the pilot assembly you will find a small orifice. I will bet that the orifice is clogged. Clean the best you can. If the small hole remains blocked. Take one strand of wire from a wire brush and push it through the hole. Put everything back together and you should be unblocked.
Was this helpful?
Yes
No
Popular Solutions for Rinnai Desa Vent-Free Infrared
Questions and Unsolved Problems for Rinnai Desa Vent-Free Infrared
Do you recommend Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)?
Answer
Answer
I purchased a house with a Glo-Warm ventless heater. It is a FS-3B serial # 8776421 and the knob is... (More)
Answer
Pilot light is always going out on my Desa vent free stove. Cleaned the pilot assembly and it still... (More)
Answer
i have a adesa model cbn 20t serial 014970796 when i hold the button down on the pilot light for 60... (More)
Answer
where can i purchase a thermocouple for this gas heater? no carries them since the company went out... (More)
Answer
Our water heater will heat up the water then after a few moments it will go cold for a few seconds... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rinnai Desa Vent-Free Infrared...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
