Question about Canon PIXMA MP530 All-In-One InkJet Printer
Fax in memory
I have recieved a fax that is stored in my fax memory. I would like to print it out but don't know how to.
  • jk_sono Oct 09, 2007
    I have recieved a fax that is stored in my fax memory. I would like to print it out but don't know how to. My printer is a Canon MP530.
  • Anonymous Dec 01, 2007
    I have received a fax that is stored in memory and know how to print it out
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Posted on Oct 11, 2007
I have a fax in the memory and don't know how to print it
Press [START/MEMORY] and the stored documents will automatically print out. If you need the step by step owners manual with pictures, please send me an email to lbrown18062@hotmail.com. Please put "sharp ux b700" as the subject.
Jun 15, 2012 | Sharp UX B700 Plain Paper Inkjet Fax
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hello, i have the Lexmark X342N the machine will recieve the fax store it to memory, but it will not print the fax. Toner was low and could be the problem. (replaced toner) How do I print the recieved...
Please try to do the following steps
1 From the control panel, press Fax.
2 Press Menu.
3 Press up or down button repeatedly until REPORTS is selected.
4 Press the check button
5 Press up or down repeatedly until Fax Call log or Fax Job log is selected.
6 Press the check button to submit
For further assistance, please contact Lexmark Technical Support.
Feb 22, 2011 | Lexmark X342n All-In-One Laser Printer
AFTER REFILLING PAPER, MACHINE DOES NOT START RECEIVING FAXES IMMEDIATELY
It sounds like you have some bad jobs stuck inside the fax's memory. First print out a memory reference report. It will show you any bad jobs stuck in the system. Delete the memory reference jobs. Then go into set up and you want to turn off the option to store failed transmisions.
The system should store jobs while it is waiting for paper. If you have a lot of stored jobs and the memory is full it will not receive any more jobs until it can print out what is stored - so it would be normal for it not to recieve new jobs until all of the old jobs are printed.
Dec 24, 2009 | Canon FAXPHONE L80 Laser
I have a panafax uf-7000. I don't know how to clear the message ''Printing Memory Rcv'D Doc''
If you can find the menu button, most times if you select setup or maintance area, find the fax recieve area.
In that part of the menu, scroll to the area where it will say store in memory, and select it to off. Select anything but store fax documents in memory will correct this problem.
Do not make multiple changes at one time while in the setup mode.
Exit the menu and try it, repeat the process to see if those changes were made, sometimes the menu does not hold the changes you preiviously made.
Oct 16, 2009 | Panasonic Office Equipment & Supplies
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
I dont remember how to recieve a fax!
I find that you have to have the fax button lit up. If it is not lit up when a fax comes in, the fax is stored in the memory. You have to hit the fax button, go into the menu and go to memory reference, then the doc # of the item in memory should appear. You should then be able to print the stored fax. Hope this helps!
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
2800 will not recieve faxes
Some models will actually stop working whenever a drum message is displayed.
Remember, you do not need a drum to fax out (only to print confirmations) so i would go ahead and change the drum.
Ons ome models you can adjust to how low you want to set it or remove it all together.
It will store it in memory for a while (providing you do not turn off the machine, and print as soon as you replace the toner)
Jul 16, 2008 | Brother IntelliFAX 2800 Laser Fax
NOT PRINTING SENT FAX REPORT
Make sure your in fax setup your message confirm is ON and not on ON-ERR. The Sf-560 also has an issue with the phone jack on the back becoming loose and causing sataic. Needs to be resoldered
Mar 26, 2008 | Samsung SF-560 Plain Paper Laser Fax
Storing Outbound Faxes not sending.
if you print a tx journal does it have an error on those you tried to send
Mar 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,219 people viewed this question
old marine
old marine
