Question about ViewSonic VX924 19" LCD Monitor
Brightness loss i was surfig the net but suddenly brightness of monitor has been lost(not totaly). than i realised that higher half of the screen is less brighter than lower half. what's happend and what is the solution? ps. i have viewsonic vx924 monitor.
  • 286 Answers
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture is at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Posted on Feb 14, 2008
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Televison & Video
My lenovo ideapad z500 monitor
type in model # on download the manual for the monitor usually just push button on monitor Menu move to brightness adjust to higher brightness
Jan 01, 2014 | Lenovo IdeaPad Computers & Internet
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
the display has a loose connection in every side. try pressing the both side by hand.
Jun 14, 2009 | Computers & Internet
My Sony Moniter suddenly turned to a bright yellow
If the display looks normal other than being yellow, it's missing blue.
This may be because of a bad cable. Sometimes the wires inside break from flexing. Try wiggling the cable (as mikeslab suggested) at the end where it connects to the computer. Also check the plug for bent pins.
It's more likely the monitor has lost blue due to solder connections to the blue output transistor or transistor failure, or that the picture tube itself has gone bad and the blue gun has quit. Tube failure is pretty rare. I've seen many cases of bad connections and transistors, though.
If the cable and plug aren't the cause, you can have a service shop check the monitor and give a repair estimate. But if this is a 17- or 19-inch monitor, you might just want to replace it. New LCD's are $150 or less. To repair yours would be around half that cost already, possibly more depending on labor and parts costs.
Apr 24, 2009 | Sony Computers & Internet
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
ViewSonic VX924 19" LCD Monitor Logo
107 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
