Question about Polaroid i733LP Digital Camera
Memory cards I got a memory card but it won't work, it's a SD it keeps saying card error what should i do!?
Most likely the SD card needs to be formatted. You should be able to have the camera do this, but if not, find a computer with a card reader and format it there.
Hope this helps,
Steve
Posted on Nov 17, 2007
Get another one, camera destroyed the usefulness of as SD Card
Posted on Dec 22, 2007
SOURCE:
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
My camera has been great until the other day. It won't recognize that the memory card is in the camera and keeps saying the memory is full. I had downloaded the card's contents and after that it...
Yes you need a new SD card, it is rare but happens where the SD card malfunctions and it is not read by the camera, it happened to me and I put in a new card and it worked find.
Jul 03, 2011 | Cameras
Hi my r4 cards not working it keeps saying sd/tf error whats wrong and can it be fixed
Yes...sounds like a problem with your micro SD memory card. Is it bigger than 2GB ? And have you tested the memory card elsewhere ?
Oct 13, 2010 | Video Game Consoles & Games
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Polaroid i733LP Digital Camera Logo
53 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
