Question about Car Audio & Video
Specs For Boxes
How much room does the orion 10d2 need in a sealedbox
    New Friend:
  • 15 Answers
Posted on Nov 23, 2013
Box specs for 10d2
this a a impedance-2 ohms speaker sealed box 0.54 cu.ft. and a ported box 1.04 cu.ft. top mountdepth 5 9/16in bottom mount depth 6 5/16" cut out dia. 9 1/16"
Nov 21, 2013 | Car Audio & Video
What is the size of the box
here you go. good luck :)
<a href='http://postimage.org/' target='_blank'><img src='http://s16.postimg.org/kl5otizud/orion_10d2.jpg' border='0' alt="orion 10d2" /></a><br /><a target='_blank' href='http://postimage.org/app.php'>windows screenshot</a><br /><br />
Oct 06, 2013 | Jl Audio 15W3-D4 Car Subwoofer
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
They seem to stick and not move when i play music
Voice coils are burnt. Usually caused by under powering and over excursion of the driver. They only move so far then jump the track so to speak. Pull the driver and put a meter on it for resistance. if it's cooked, it will say 1.....
Any car audio shop can do this for you as well, usually for free. Hope this helps
Jun 18, 2010 | Orion HP 10D2 Subwoofer - 10" Dual 2 Ohms...
Spacks on 15" orion 2 xtreme sub
Here are the Specs from Orion's spec sheet.
Sensitivity @ 2.84V/1m 93DB
FS 23Hz
QMS 9.05
QES 0.47
Qts 0.44
BL (Force Factor) 8.7 TM
SD (Piston Area) 500 sq.CM \ 78 sq. in.
VAS (Volume Acoustic suspension) 224 Liters \ 7.92cu.ft
Xmax 7.75MM \ 0.30 in.
Enclosure Recommendations
Sealed Volume 1.60 cu. ft.
Vented Volume 2.75 cu. ft.
Port Dia (Inside Dia.) 4 in.
Port Length 8.5 in.
Nov 07, 2009 | Orion Xtreme XTR15d Car Speaker
Have an old model orion amp needing specifications
the specs are as follows
250watts x1 at 4 ohms
400watts x1 at 2 ohms
600watts x1 at 1 ohm
it is bridgeable and has a 50 amp maxi fuse
May 09, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion and TV Converter box
Most converter boxes will hook up to your tv if it has an antenna jack. I'm guessing the list you were looking at was a list of converter boxes that could be purchased with the governments coupons, not a list of tv's. I hope this is helpful to you. Make sure the converter box you buy has coaxial out to tv jack(it will look like the ant in jack).
Apr 16, 2009 | Orion1934 19" TV
Orion hcca
The owner's manual states the ported box should be:
  • 4.00 cu ft.
  • Port diameter = 4"
  • Port length = 14"
It doesn't mention round vs. rectangular port. For more details, you may want to contact Orion.
Mar 20, 2008 | Orion 15" Competition Subwoofer H2 15D4...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
