Question about Sunbeam Coffee Makers & Espresso Machines
Sunbeam cafe espresso EM3800 - trying to use it for the first time, however it will not flush with water. The reservoir is full and appears to bit fitted in place correctly. The appliance heats ok a
Explained above
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Posted on Nov 29, 2009
SOURCE: Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
Posted on Feb 10, 2010
SOURCE: sunbeam em6910 not getting any steam
Perform a factory reset of the thermoblock temperature. I had the same problem and even though I had never adjusted the temperature to a custom setting, this quick procedure fixed it immediately. Instructions on last page on your manual or download the manual from the manufacturer's website.
Posted on Jun 13, 2010
espressonist
  • 1711 Answers
SOURCE: Display says "brewing" but no water gets pumped .
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 20, 2010
Group head not running
Perform a full descale. Take out the water reservoir and remove the Anti-calc filter. Put in 500ml (1 pint) water with 3-4 tablespoons of white vinegar (or apple cider vinegar). Put the water canister back in, the turn on the machine and press the manual button. Allow half of the liquid to go through, then stop. Leave the machine for about ten minutes, and then run the rest through. Empty the water reservoir and rinse, put back the Anti-Calc filter, put in another 500ml and press the manual button to flush it all through.
May 11, 2014 | Sunbeam Cafe EM6910
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
Sunbeam EM3500
Jan 19, 2014 | Sunbeam Coffee Makers & Espresso Machines
Low water indicator flashing
The magnet inside the float loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Jan 09, 2014 | Sunbeam Cafe EM6910
Service manual
Jun 18, 2013 | Sunbeam Cafe EM6910
Leaking water under the drip tray
First, be sure to regularly push a straightened paper clip in that nozzle! It can get clogged with coffee grinds quite easily.
Then call Sunbeam and tell them you want the waste chute extender. It's a little plastic tube that fits over the nozzle to extend it further into the drip tray. Truth be told, you could probable push a 2cm piece of 3mm aquarium pump air tubing over it.
May 22, 2013 | Sunbeam Coffee Makers & Espresso Machines
Red light flashing even though water tank is full
try to check the floating magnet inside of reservoir tank.
Nov 06, 2012 | Sunbeam Cafe EM6910
EM6910 - I am having problems with the pressure from the steam. Any suggestions on how to fix it.
Have a look at your manual and see if you can adjust the steam pressure. I saw it recently as I'm having trouble with the red light flashing despite the water reservoir being full. Hope this helps.
Oct 05, 2012 | Sunbeam Cafe EM6910
How to clean and descale sunbeam cafe thermoblock
red light flashing next to water meter of sunbeam coffee
series and making a noise
Mar 20, 2012 | Sunbeam Cafe EM6910
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
21 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
