Question about ASUS P5LD2-VM Motherboard
Hard drive power
My problem is that my father just ordered me a maxtor sata II/300 7200rpm 200 GB hard drive, whenever i connect the power cables my computer wont start. The fans will spin for about half a second showing the computer turns on, but then the computer instantly shuts off. The computer will only turn on when the drive in NOT connected. I have failed in any atempt to install this new hard drive. What should i do?
    Problem Solver:
  • 10 Answers
I have seen this only when the Power Supply is underpowered.
You may have a 200Watt or 300Watt PSU and the drive is pushing you just over the edge of what the supply can deliver.
Even if the power supply is big enough - it may not be delivering the 'Rated' power. That's the first thing I'd look at- because your symptoms are an exact match..
Posted on Oct 31, 2007
What is the model of the motherboard that you are trying to connect the sata hdd to?
Posted on Oct 09, 2007
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
How 2 install in my new hp also have a burner on same cable burner works but both dont work 2gether
a dvd burner on same bus as a hard drive..the cable needs to go to hard drive first then the dvd that the case? also, if it's SATA, the order on which cable comes from the board to hard drive SATA 0 is critical
Dec 06, 2009 | Maxtor (6L250R0) 250 GB Hard Drive
Part No. 9W2874-582
Sata drives use both 5V and 12V power. The standard SATA connector found on most current power supplies carries both. If you're trying to rig up some temporary power just hit your local PC shop and ask for a Molex to Sata adapter that will connect your old power supply to the new drive or pickup a USB to SATA adapter kit as they usually have there own Sata capable power adapter.
Hope this helps FixYa,
Oct 21, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I plug my Maxtor 3200 into my laptop that is running windows vista, and it does not show up? What do I do
check the interphase
2) the electronic interphase between the hard disk and the outlet firewire or usb port going to the pc
3) if there is no spin up when you connect the drive directly through a sata or ide interphase then the drive has to be sent for data recovery and replacement as certain ata modules may not be working
dr arora
Aug 18, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
So here I was in the playground and then came these guys they were clearly up to no good before i knew I accidentally the whole coca cola bottle, is this bad?
The whole bottle of Coke spilled on the drive? Make sure you DON'T power it on, because the hard drive's controller board could short. You may still be able to recover the data if you disassemble the unit and place the actual hard drive in another computer, or connect it with a SATA or IDE/USB connection cable.
Jul 07, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
ASUS P5LD2-VM Motherboard Logo
35 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
