Question about Dell UltraSharp 1905FP 19" LCD Monitor
Dell monitor light blinking no picture - Dell UltraSharp 1905FP 19" LCD Monitor
(montior)on light is blinking on and off NO picture
You can look at my pictures to see what is usually wrong with your DELL monitor:
http://s807.photobucket.com/home/budm/allalbums
Most of the time are due to bad caps, bad soldering works, shorted transisotrs, etc.
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell E153FP 15" LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
Power light blinks with no picture
Look for bad fuse and transistors in the inverter circuits, see picture of failed Dell monitors here: http://s807.photobucket.com/home/budm/allalbums
Mar 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
After hibernate mode monitor blinks on and off. The monitor is on power is being feed to monitor however if you turn the power button on and then off the picture on the screen will blink on and then off
If it is your computer that is in hibernation then blinking on the monitor light is normal
Just bring your computer out of hibernation and the screen will come back to life too
Aug 22, 2009 | Dell Computers & Internet
Front panel lights blink on/off once per second
Hey,
I would like to agree to the diagnosis that you have done on the monitor . Thanks for a well complied solution. You can try the following website
http://werepairmonitors.com/monitor-repair.htm
dell generally sources the monitors from NEC,Hitachi or LG.
Thanks
proton
Mar 23, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell flat panel monitor blinks no picture
Do you Mean the power Light blinks? It seems that the monitor has gone on Standby mode due to no connection (Or so it thinks) It is very Possible that the Driver to your video card has been deleted or you may need a new one.
Jan 10, 2009 | Computers & Internet
1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Sep 28, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Aug 14, 2008 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 1905FP 19" LCD Monitor Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
