Question about VillaWare 5785 Smoothee Bar Work Top Blender
Jar blender blade bottom screw on piece
Need new screw on piece on bottom of blender jar that secures blender blade to Jar, also need gasket
  • 7 more comments
  • Avsfanco Nov 13, 2007
    If you have found one please let me know, The seal between the blades and the housing has come apart and now leaks
  • Anonymous Mar 18, 2008
    I need the bottom (blender blade).This is my second replacement. I was able to find one previously but can't seem to find one online. Also would like to purchase a glass replacement for the plastic jar.
  • Anonymous Apr 27, 2008
    broken plastic tabs on screw in blade base assembly
  • Kellygirl1 May 18, 2008
    I have the villaware smoothee bar and I need the ring that holds the blade base in securely. Can that be replaced and if so where can I find it?
  • erroljharris Dec 25, 2008
    my jar base with blade came apart to can i find a replacememt?
  • lgarcia754 Apr 24, 2009
  • Anonymous May 12, 2009
    Two of the tabs that are used to hold the bottom blade piece to the pitcher broke off. I'm also looking for a replacement blade. Otherwise I think the blender is great. I usually don't use the spout.
  • Anonymous Mar 18, 2014
    I need to to buy jar blades for farberware blender
  • Anonymous Mar 23, 2014
    need jar to fit into bottom half of blender not go all the way down
Villaware 1-866-484-5529
Posted on Nov 20, 2007
  • Anonymous Nov 20, 2007
    call villaware 1-866-484-5529
SOURCE:
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Misplaced manual. How to assemble Cuisinart Smartpower 7 speed electronic blender- Specifically need to know where to place the gasket.
Hello, W/D here.
You can download your manual here:
http://www.cuisinart.com/manuals.html
It is at the bottom of the page.
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Best regards, --W/D--
Jan 30, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
VillaWare 5785 Smoothee Bar Work Top Blender Logo
1,550 people viewed this question
Top VillaWare Blenders Experts
Steve Allison
Steve Allison
 Mike M
Mike M
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
