Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 power but no picture...
I have the above listed television and loved it until tonight. The tv worked fine this morning and then this evening the picture just wouldn't appear. The power comes on and there is a static sound in the audio but no picture whatsoever. Any information would be appreciated! Thanks.
  • RCA Master
  • 5,138 Answers
Solder around flyback pinns this should fix it.
Posted on Feb 17, 2008
  • ladywinn
    ladywinn Sep 10, 2008
    Flyback Transfomer is located on power supply board on same board Set has problems with 3 green&gold capacitors 2200uf 16 and (2) 330uf 35volts.
Thanks alot!,
Where would I find the flyback pins? Is there a schematic of this anywhere that would be available to me? I appreciate it.
Posted on Feb 26, 2008
SOURCE:
RCA D52W19 52 doesn't power up and have a picture
press and hold the power button for a few seconds. it should blink some codes. does your tv try and power itself on a few times. does it not show power at all. need more info to determine cause.
Jun 13, 2010 | RCA D52W19 52" Rear Projection Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | RCA D52W19 52" Rear Projection Television
Working fine, then shut off.. won't come on, no power
A clogged air vent will cause the unit to overheat and not turn on.
Apr 16, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Jan 01, 2009 | RCA L42WD22 42 in. LCD Television
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
93 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
