Question about Samsung Office Equipment & Supplies
My printer is ticking what is it - Samsung Office Equipment & Supplies
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
How do you retrive the meter read on the HPLJ4250TN
allow the machine to come to ready
press the TICK button press down untill Information press TICK press down until Print config pages press TICK - take config pages from exit tray
Done!
Jan 14, 2014 | HP LaserJet 4250n Printer
The printer doesn't recognise a new transfer kit
To reset the transfer unit count, do the following:
  1. Press the green tick to enter the MENUS.
  2. Press the down arrow to highlight CONFIGURE DEVICE.
  3. Press green tick to select CONFIGURE DEVICE.
  4. Press down arrow to highlight RESETS.
  5. Press green tick to select RESETS.
  6. Press down arrow to highlight RESET SUPPLIES.
  7. Press green tick to select RESET SUPPLIES.
  8. Press down arrow to highlight NEW TRANSFER KIT.
  9. Press green tick to select NEW TRANSFER KIT.
  10. Press down arrow to highlight YES.
  11. Press green tick to reset the transfer unit count.
Jun 21, 2010 | HP LaserJet 4650n Printer
I have a deskjet F300 HP
Goto Start > Printers and Faxes.
See whether your printer is set as the default printer. (Default printer icon has a tick mark next to it).
Double-click the printer icon.
You will see a list of documents pending. Delete all the files. (Or select an item, and from document menu, click cancel. Do this for all the items).
Close this window.
Right-click the printer icon and see whether 'Pause printing' is ticked. If so, click it to remove the tick mark.
Restart the printer and the computer. (This is optional, but better to do it).
Now it will be OK.
Aug 12, 2009 | Office Equipment & Supplies
Making a funny noise as if it is not taking in the paper but it
I have found the issue with non-Samsung printer cartridges. I don't get the problem with Samsung cartridges.
Dec 11, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Intermitent Ticking
I determined that there was an incorrect connection from the printer to the main phone line jack. The DSL connection and the printer were reversed.
Sep 17, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have to press the tick every time i print
If you go into the printer config there should be an option for "manual feed." Turn this off and it should fix your issue.
Feb 08, 2008 | HP LaserJet 2300 Printer
CANNOT PRINT WITH NEW COMPUTER
I had many problems with Vista fixed in this way.
1) Unistall drivers supplied with printer
2) Download new Vista drivers
3) Disconnect printer
4) Restart computer
5) Install new drivers (connect printer when it asks)
6) Restart computer
For me it now works.
Jan 15, 2008 | Lexmark Z640 InkJet Printer
12 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
