Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
IMac and ADVC 110 via firewire = Nothing
Playing tape on Sony VCR connected to ADVC 110 via Video patch cord (red, white, yellow) and ADVC 110 connected to iMac via firewire. Lights are on. How do I get record video when the computer does not see the ADVC or the VCR?
  • 2 more comments
  • smohan Nov 20, 2007
    I have exact same problem here with my iMac and ADVC110. It worked perfectly before and it just stopped working. Lights are on, but my iMovie won't recognize it via firewire. What is wrong?
  • richardinatl Jan 05, 2008
    I have the same exact problem.  I even tried using two different VCR's to no avail.
  • captkub Jan 11, 2008
    ok i hit the wrong link....i don't have a solution
  • Anonymous Mar 05, 2008
    hi same probleme here :-\
This just happened to me tonight...whats going on?? is this some recent leopard related error?
Posted on Jan 11, 2008
Camcorder to vcr a/v hook up and record
All you need is an connecting lead that comes out of the camcorder and that terminates in three phono plugs. One yellow (video) one red (right audio) and one white (left audio). As you can see from the stock picture on your post the VCR front has the corresponding coloured sockets. So you plug them into that. Sometimes these sockets are hidden on a cover. If your VCR hasn't got them, you can use a scart socket located on the back. You get a scart plug with the same connections. If it has male plugs you will need to get 3 female in-line connectors to connect your leads.
Once connected using the VCR menu or the channel selector, select the AV socket you have connected the camcorder too. Start it playing and you see the picture. Providing you have a tape in the VCR pressing record will capture the picture from the camcorder.
Feb 06, 2015 | Televison & Video
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
How do you tape on vcr from a vcr?
The 'quick and dirty' way is to connect the VCR playing the tape via the RF OUTPUT coaxial connector to the RF (sometimes ANTENNA) connector on the recording VCR with it set to channel three or four. BOTH units must be set to the SAME channel. The better way is to use the RCA jacks and all but the very oldest should have a yellow jack (Video) output connected to the other unit's (yellow) video input and for sound, the output white jack connected to the white input jack (left channel) and the red output jack would go to the red input jack on the recording unit. This latter method yields a cleaner signal than the first method.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
How to copy
use s video cord or red white yellow cord to connect. camera comes with a grey adapter patch cord that will help do that easily.
May 02, 2009 | Sony Handycam DCR-TRV30 Mini DV Digital...
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
ADVC-110 not working for me
iMovie or Final Cut Pro should work.
Sep 18, 2007 | Canopus ADVC-110 A/D Converter...
ADVC110
I'm guessing that you have it connected via a 6pin firewire on the ADVC100 to a 4pin firewire on your macpro. The device needs to be connected via 6pin to 6pin in order for the device to get power, otherwise you'll have to buy a AC adapter (which is not included). Otherwise it's a great device for DV conversion on multiple platforms!
Mar 23, 2007 | Canopus ADVC-110 (77010150100) Video...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
450 people viewed this question
Top Canopus Televison & Video Experts
Archie Ferrarini
Archie Ferrarini
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
