Question about HP Photosmart 635 Digital Camera
Camera Connection Hi, I am having problems with my camera connection to my computer. It is hooked up via USB, but my computer is not recognizing the problem. Any tricks or ideas I can use to get it going?
  • bevand4 Sep 22, 2008
    MY COMPUTER AT ONE TIME DID DOWN LOAD FROM MY CAMERA, BUT I LOST THE CAMERA AND NOW THAT I HAVE IT AGAIN (AND IT IS WORKING FINE) THE COMPUTER WILL NOT RECONIZE THE CONNECTION. I MAY HAVE REMOVED SOMETHING ON MY COMPUTER? WHAT DO I DO?
    Problem Solver:
  • 5 Answers
Two things:
1. The USB cable where it connects to the camera has to firmly in place otherwise it can disconnect from the computer even though it appears to be connected.
2. In the HP 635 'Set up' menu there is a section called USB configuration that has a 'computer' icon and either of these two options:
USB (Digital Camera)
USB (Disk Drive)
Set it to USB (Digital Camera). This tells your computer what sort of device is connect to it.
If you are connected correctly as above this is what happens:
1. Message: 'Establishing connection with computer'
2. Message: 'Connected to computer'.
3. images are copied to the computer.
I hope this helps.
Posted on Feb 19, 2008
How do I upload photos from a Canon PowerShot A95 digital camera to a 2009 Apple MacBook via USB?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jan 06, 2013 | Cameras
Downloading Pictures to my computer
Hi Demmie, You should not have a problem if you hook the USB into the camera, and then into the computers USB port while the computer is booted up and running. The computers Plug and Play stufff will recognize that a camera has just been connected. You can aloow Adobe photoshop, or any other Photo program to get your photos. Their are too many photo handling programs to list in this format. Just feel secure that when you connect to the computer something will pop up and tell guide you to sucess. You will probably have to turn on the camera first, or your camera will prompt you to ok the connection to a pc. You will need to ok the connection on the camera if it asks.
Oct 07, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hi, Im having trouble getting the olympus master software to recognize my fe 340 connection via USB port. This has suddenly occured , preventing me from uploading and transferring new images. I've never...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 11, 2010 | Olympus FE-340 Digital Camera
My camera samsung wb500 cannot be recognized by a computer. When plug it in to the computer via usb cord it is recognized by the pc. The light on the camera flickers but nothing happens. Thus I am not...
Cross your fingers and hope it is just the cable. The flashing light shows it made a momentary connection. The connectors get loose from use and abuse. They are not expensive to replace. If you can find a store or camera shop or have a friend with the same cable they should have one you can use to test. You don't need to transfer anything just plug it in and see if it connects normally. If it does then buy a new cable. If it doesn't then the problem can be the connection inside the camera or the usb interface inside the camera. Unfortunately those are not going to be a cheap repair. You would spend as much as a new camera. So unless you have warranty left it comes out of your pocket. A new replacement camera will usually be as cheap or cheaper than the repair cost.
Sep 04, 2010 | Cameras
Computer no longer recognizes camera via USB connection
Consider NOT connecting your camera to your computer.
Oct 09, 2009 | Canon PowerShot A85 Digital Camera
Camera wont sync with any computers
YOU HAVE TO INSTALL DRIVER BEFORE YOU HOOK THE USB CABLE.
Jul 23, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
No connection with my camera and computer
Dec 24, 2008 | Canon PowerShot SD1000 Digital Camera
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
I cant put pictures onto computer?
you have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
Jan 06, 2008 | Samsung Digimax S630 Digital Camera
COOLPIX CAMERA 5200
You might be more successful if you provided a little more information. Is your computer a Windows PC or a MAC? Have you tried connecting the camera to the computer via the supplied USB cable? Assuming you're using a Windows machine, you can simply transfer the images using Windows file services, without needing to install any additional software. When you connect the camera to the computer via the USB cable, Windows recognizes the camera as a removable drive and assigns it a drive letter (e.g. drive G:). An icon for the "drive" appears in your MY COMPUTER window. (a) You double-click on the MY COMPUTER icon - (b) double-click on the drive ICON that represents your camera - (c) locate the folder where the image files are stored - (d) and simply drag the folder to your desktop (or wherever you want the images on your computer's hard drive). If you don't know what I'm talking about, then you need help with basic computer usage. If you're having a problem with the USB connection (e.g. the computer doesn't recognize the camera) then you should provide some more details about this problem.
Jun 09, 2007 | Nikon Coolpix 5200 Digital Camera
HP Photosmart 635 Digital Camera Logo
390 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
