GE DWSR405EBWW / DWSR405EBCC Electric Dryer
Problem for GE DWSR405EBWW / DWSR405EBCC Electric Dryer
Ge dryer
By steelspur on Oct 09, 2007
I have a ge dryer, model DWSR405EB....ser# ZD719441A. Recently it has started taking a long time to dry clothes. There is a little heat but like I said it takes hours to dry a load of clothes. Do you think this is the thermostat? Any ideas? If you think this is the problem, can you tell me the steps involved in changing it? Thanks in advance..Grant
Comments:
Oct 09, 2007
- Yes, I have cleaned the lint trap and the inside of the dryer as well as the dryer vent hose. They were all vaccumed out. I thought it may be the element but was told that they rarely go out and since it was just 3 years old, that it may be the thermostat.
Oct 09, 2007
- The only panel on the back that can be removed is the cover that goes over the connections for the power wire.
Same Problem
Feb 12, 2008
-   I have the same problem with a model # DBXR453ET5WW. It takes a very long time to day one load of clothes. I have checked the vent system as recommeded. No clogs. I opened the door, started the dryer on high heat, and could see the heating elements turn red, but they only stayed red for about one minute or less. Could this be a thermostat causing the heating element to shut off?-   Wetclothes2
Best Solution
posted on Nov 30, 2007
Helpful)
GE-MAN
Rank: Apprentice
Rating: 91%, 8 votes
i built these machines... before doing anything ...check your fuse box or breaker .... 240 v .... it goes out often ... if its not that ... its probably your element ... ...open your door and on the top of the opening ... there 2 screw ... take the top off then the front ... 2 other screws ...take out drum ...and check element ... its about 60 for a new one
Was this helpful?
Yes
No
Solution #2
posted on Oct 09, 2007
Somewhat Helpful)
PCFI
Rank: Guide
Rating: 78%, 12 votes
Have you checked the lint trap and exhaust piping(I forgot what it's actually called)
if there is poor air flow through the dryer
it will dry extremly slow. I'd check these items first. if that is not it, it is probably an open heater coil, I personally have not seen too many thermostats go out.
Comments:
Oct 09, 2007
- Usually inside the rear cover there is a wiring diagram. if you have an ohm meter you can easily ohm out the heating elements and determin if one is open. if both read the proper resistance (per the diagram) then your thermostat is your problem.
ABOVE ALL>>>>PLEASE MAKE SURE THE DRYER IS UNPLUGED PRIOR TO PERFORMING ANY SERVICE TO IT.
Was this helpful?
Yes
No
Popular Solutions for GE DWSR405EBWW / DWSR405EBCC
Questions and Unsolved Problems for GE DWSR405EBWW / DWSR405EBCC
Do you recommend GE DWSR405EBWW / DWSR405EBCC Electric Dryer?
Answer
Answer
Dryer on/off button will not stay in as if no power. Have changed fuse
Answer
Replaced heating coil but dryer still not drying clothes and a small puddle of water in right front... (More)
Answer
can i inspect the heating elements by removing the deflector in the rear of the drum
Answer
We have had this dryer for about 5 years and love it. We have never used the hat dryer and we have... (More)
Answer
i was drying a pair of tennis shoes and somehow they jammed the dryer and it was unable to turn..it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
