Question about Royal VF1012mx Shredder
How to get paper out of the teeth of a shredder
  • 35 Answers
SOURCE: My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Posted on Mar 03, 2009
  • 1218 Answers
SOURCE: Thanks! I have a 7x
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Posted on Oct 20, 2010
  • 1218 Answers
SOURCE: how do I unclog my shredder? The papers keep
Have you ever "oiled" the cutting blades...all cross-cut shredders should be oiled regularly otherwise they clog up with the paper and debris generated by the cutting of the paper...the oil helps feed this material on thro into the shredding bin.
Posted on Mar 30, 2011
  • 1218 Answers
SOURCE: Royal paper shredder head for SC180MX. Some of
For parts assistance contact Royal at 1-800-524-0799.
Posted on Jul 20, 2011
envisage600
SOURCE: repair parts for a royal paper shredder
I'm just trying to update this answer the number for parts is incorrect and I spent over 2 hours on hold without result. I then called the product support number and was re-directed to the sales number. When I called it I spoke to a very helpful rep who listened to my story and immediately transferred me to parts where the service technician was EXTREMELY helpful in identifying the part required and then taking an order to get the part shipped. The cost of the plastic gear was $3.16 I didn't ask what the shipping was...
Sales phone number: (888) 261-4555
web address: http://www.royalsupplies.com/contact-us.html
Posted on Oct 10, 2012
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
My omnitech shredder OT-NXC8PA stopped working after clearing a paper jam. Seems the machine is running, but not sucking papers.
I think you just fried your gears. The motor is fine, but the gears that connect the motor to the shredding mechanism have had the teeth flattened up. No teeth on the gears = not shredding papers. The gears are made of plastic anyway.
Jun 26, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Cuts through paper but does not shred completely
You need to disassemble the unit and then sharpen the teeth of the shredder. Use can use sand paper, one by one sharpen it until all the metal teeth of the shredder becomes sharpen. I hope my advise help you. Good luck!
Jun 05, 2011 | Tech Solution TS-4500 Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
Oct 19, 2010 | Royal Office Equipment & Supplies
Paper won't feed into shredder
maybe a security feature needs top on to run.
Jun 10, 2009 | Cross Infoguard Shredder SX102M
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Royal VF1012mx Shredder Logo
121 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
