Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Monitor turns off after 2 seconds - Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
Image displayed for 2 seconds after powering monitor on
The problem could be the CCFL lamp, especially if the image has a pink hue.
Check LCD Parts for service, parts and DIY info. use this link :-
www.lcdparts.net
Sep 20, 2009 | HP f2105 21" LCD Monitor
My 906 bw shuts off after 2 seconds, if i turn
Actually, this problem can be fix going to power management under control panel. You have to log in in safe mode in order change configuration. It displays stand by monitor and you choose the time that you see fit.
Aug 30, 2009 | Samsung 906BW LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes black for a few seconds
Try swapping the monitor cable from the working monitor to the other video connection on your computer. Effectively reversing the connections to isolate whether your problem is the video card in your computer or the monitor itself. If you find the working monitor displaying similar symptoms, then check your video drivers and ensure that you have all power saving features, screen savers, etc... turned off.
Apr 06, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
On off problem
Sounds like it's faulty. is it under warranty?
Feb 20, 2008 | ViewSonic VX924 19" LCD Monitor
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
