Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
Paper jam 1
Displays the paper jam problem 1 and not let you do anything. I checked the equipment and I have extracted a small piece of paper, but still the same. Apparently neither toner or fuser have problems.
  • quiquejavi blancomar Nov 21, 2013
    Fixed bug. Thanks anyway :)
    In the end it was just a bit clean the fuser.
  • 794 Answers
The problem may lie in the fuser or imaging drum; there may still be small pieces of paper jammed in them or any where else along the paper feed roller/trail. If you do remove the fuser or any of the other consumables, make sure the printer is turned off and the power cord removed at the outlet (receptacle). Allow the fuser enough time to cool down. Serious burns (1st, 2nd, and 3rd degree burns) can occur- the fuser gets extremely hot.
Should you need to remove the imaging drum to inspect it for any more tiny pieces of torn paper, do it in a very dimly lit room; use a black plastic garbage bag to store it in. If the imaging drum is exposed to direct light, especially sunlight- you will damage it completely, or possibly shorten the life of it; very expensive to replace.
If there is serious damage other than what I covered and it is going to cost more than half or 2/3rds of what the printer is worth, you're best option is to buy a new one; and dismantle the damaged printer for its precious metals- you can get some money back at the scrap metal yard for the gold, copper, steel, and aluminum; and recycle the plastic parts for $$ too, if available in your area.
Posted on Nov 22, 2013
Testimonial: "Thank you very much. There was not more pieces of paper. What I did was remove the fuser and clean it up a bit. After that, it worked without problems."
  • Radlie Hunter
    Radlie Hunter Sep 24, 2014
    Just give the scrap metal business a call and they can tell you whether it's worth taking apart to sell. You can also try selling it on local ad sites to recuperate the losses. http://www.macstraders.com
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
  • 208 Answers
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
  • 2072 Answers
SOURCE: Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Posted on Jan 23, 2008
  • 2072 Answers
What code is comming up with the jam? That would help me narrow it down for you.
Posted on Apr 05, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
Posted on May 06, 2008
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
4300n hp printer displays a 13.20.00 jam inside rear door.I cleaned everything& I couldnt find any jammed paper so what might be the problem
just carefully check for small pieces of paper inside ot printer,
Look for "lasy" sensor flags etc.
Also remove toner cartridge and check inside for paper.
May 13, 2011 | HP LaserJet 4300n Printer
My printer says it has a paper jam but there isn't anything in it
What is your printer model? You might check for any small pieces of paper left under the rollers. Sometimes a small piece is left when you yank out a jammed paper. Check it out.
Nov 26, 2010 | Office Equipment & Supplies
Canon mp830 displays error message. Paper output
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
After paper jam printer displays error light and will not function
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
Konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Feb 04, 2009 | Konica Minolta PagePro 1350W Laser Printer
Piece of paper 1 inch by 2 inches jammmed and won't eject when I touch start button. I can't even see it with the cover open.
you have to open up your printer covers to extract that jammed paper. However, if you haven't tried tinkering with anything electronic before you will have to seek technical assistance from a qualified expert, but if you're willing and determined to extract that piece of paper, i suggest first you unplug any power connection from your printer, then unscrew the visible screws of the cover which is nearest the jammed piece of paper. never turn any cylinder if it resists your effort, however, try to manually turn cylinders where that small piece of paper is wedged until it comes off. Try to pull down on that piece of paper using a hair puller or forcep.
Apr 01, 2008 | Computers & Internet
Paper jam message will not go off - so unable to print . there does not appesr to be anything in the printer. have tried every thing i can think of. help ireally need to print
Do a careful check for anything stuck in the printer- a small piece of paper, paper clip, or even a small piece of broken plastic from the printer itself. Anything that can jam up the works, or hold a paper sense sensor in an activated position can give you a problem like this. Also, the paper sensor itself could have a problem. This sensor is in the paper path somewhere.
Jun 11, 2007 | HP Photosmart C4180 All-In-One InkJet...
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
