Question about HP Compaq Business d530 Ultra-Slim PC Desktop
HP D530 SFF desktop
My computer D530 SFF is not Ultra-Slim , But probably has same problem with ultra slim desktop PC power supply. Power supply still working , but I'm worry about possible overheat problem. Looks like a bad design. Connected to the power supply 12V fan working with around 20% of necessary duty , air flow is very slow. Applyed voltage to the fan around 4.5V instead 12V. My question : D.C. voltage for the fan regulated automaticly by computer or not? Thank you
  • 1 more comment
  • surve_dev Dec 02, 2008
    my hp d530 desktop, & its smps fan is not working due to this my system get hangged after 1/2 hour
  • Anonymous Mar 12, 2014
    Instructions on how to restart from the Boot Menu using a DVD on a HP Compaq dc7700 Ultra-Slim Desktop
  • Anonymous Mar 28, 2014
    need owners manual
Dear MUKHTAR. Thank you very much for trying help. Problem is construction. To disconnect existing fan I must remove power supply, because wires for fan coming from inside of it. How to raise voltage for exist. fan - I don't know . That is should better solution .
Posted on Oct 09, 2007
    President:
  • HP Master
  • 2,022 Answers
It is depend up on the power supply connector and it will give the output according to the smps you can do one thing try with installing other fan and see is it in perfect rotation. bye
SOURCE:
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Remval of power supply from hp d530 compact desktop
there are 4 screws on the back of your computer that will release the powersupply at that point you should be able to just slide it out keep mind were you unplug things
Company site http://www.attechcomputers.co.cc
Jun 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
LED light is orange but computer is on.
it sounds like you may have overloaded the PSU, best thing to try would be to take out the dvd burner and and try booting again, if this doesn;t have any affect it may mean you need a new psu (power supply).
Mar 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
My compaq d51s won't boot up
unplug computer wait 5 mins then replugin computer and reboot, if same thing happens , it means u have a short in the power supply. replace the power supply.
Jan 17, 2009 | HP Compaq d530 Ultra Slim PC Desktop
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Cpu, hd, mem from this d530 slim...
*check the model number of the motherboard and replace the same so that it support your system
Jun 25, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Won't turn on
Hi
The problem is overheating please remove and replace the processor fan.
Jyo
Jun 20, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
725 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
