Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Canopus ADVC-110 Connected to Sony VCR via Video patch chord (red, white, yellow) and connected to iMac via firewire. No AC adapter included with the unit. My computer does not see the unit. I cannot record video from the tapes. Help!!!!!!!!!!!! CK
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Posted on Jan 06, 2008
How do I get the video out firewire option to become avilable with my canopus box?
You are found your advc video capture has rear and front cable connector so you can find this very simple.
Nov 28, 2009 | Canopus ADVC-110 (77010150100) Video...
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
Canopus ADVC-100 not sending a video signal
The device requires 5V 2A to work, it doesn't work with less than 2A.
Feb 28, 2017 | Canopus ADVC 100 (770-10072-100) Video...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Canopus ADVC 110 converter box not working
Plugging in the FireWire backward, especially if it's the 6-pin FireWire, will damage the unit's hardware. You need to contact technical support to arrange for repair.
Mar 11, 2008 | Canopus ADVC-110 A/D Converter...
ADVC300 faulty
Check that you have power to the unit via the supplied AC adapter.
Otherwise you need to contact technical support. The unit sounds like it is damaged.
Dec 22, 2007 | Canopus ADVC-110 A/D Converter...
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
ADVC-110 not working for me
iMovie or Final Cut Pro should work.
Sep 18, 2007 | Canopus ADVC-110 A/D Converter...
ADVC110
I'm guessing that you have it connected via a 6pin firewire on the ADVC100 to a 4pin firewire on your macpro. The device needs to be connected via 6pin to 6pin in order for the device to get power, otherwise you'll have to buy a AC adapter (which is not included). Otherwise it's a great device for DV conversion on multiple platforms!
Mar 23, 2007 | Canopus ADVC-110 (77010150100) Video...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
211 people viewed this question
Top Canopus Televison & Video Experts
Archie Ferrarini
Archie Ferrarini
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
