Question about Gateway FPD2275W LCD Monitor
Why does my monitor have a usb port - Gateway FPD2275W LCD Monitor
My usb port on monitor isn't working. how can i fix this?
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Can i play movies as well as music via a usb memory stick for my lg flatron m1962d-pc monitor
The USB port on this monitor is just the USB hub than expands your PC USB port to the monitor (USB port of the PC will have to be connected to the USB in of the monitor). It is not a stand alone USB port.
Feb 17, 2011 | LG M1962D Monitor
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
How to use USB ports in BenQ E2420HD monitor? Can I connect pen drive..........
The USB ports on the Benq monitor is a USB hub. Connect a USB cable from the USB port on the computer to the input USB port on the Benq.
Then you can connect any USB devices to the USB port on the Benq and the computer will see this device.
Nov 15, 2010 | Computers & Internet
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Why don't my USB ports on my monitor work
1) good USB cable from Monitor USB input port to PC USB port?
2) Check pin 1 of the USB port, you should have 5vdc.
3) Your monitor's USB ports are basically the powered USB hub, but it must be connected to the PC USB port.
Jan 25, 2010 | Dell E176FP 17" LCD Monitor
The monitor has 2 USB ports on the left side of
It is basically 2-port USB powered HUB built into the monitor, did you hook up the USB cable from the monitor USB Input port to the USB port on the PC?
Jan 08, 2010 | HP w2207 Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor usb
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Feb 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Gateway FPD2275W LCD Monitor Logo
14 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
