Question about Aiwa AV-X200
Plugged in 220v by mistake
I plugged my receiver by mistake into a 220v. i already replaced the fuse but still there is no power. what should i replace next? thanks in advance.
  • goliath6900 Oct 09, 2007
    what's a trafo? the step down transformer where i am supposed to plug it in? yes i checked the transformer already. nothing wrong with the transformer. i dont get any power. not even the clicking sound. when i press the power, nothing happens. is there a transformer inside the amp?
    where is the secondary coil located and how does it look like? i tried take out what seems to be a transformer but its wrapped with a metal housing. couldnt see what was inside.
  • 93 Answers
Did you check trafo? Do you get any power on secondary coil?
Posted on Oct 09, 2007
By mistake I plugged in my Harman Kardon elegant 2.1 system into 220v instead of 110v. No there is no power. Please advise.
There is an over-voltage protection fuse, but, it is inside the transformer. It can be replaced by experienced service technician. Contact any one such.
Oct 03, 2013 | Audio Players & Recorders
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
Is there a replacement fuse or power supply for Husqvarna Viking 990??
check with husqvarna customer service about the fuse or power supply
Feb 27, 2012 | Husqvarna Sewing Machines
On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
Sep 02, 2011 | Coleman Powermate Premium Plus 6250W...
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Jul 05, 2010 | Televison & Video
I have a set of stereo computer speakers, Altec Lansing, Model #BX1121 ''Powered Audio System'' that has a subwoofer and a left and right speaker. When I plug the system in and turn the power on, I get...
i did the same thing when i was over seas, damn 220v, and all it did was blow the fuse in the unit, if you have an inline fuse (along the power cord) it might have blown there, if not you will have to take the unit apart and change the fuse, might be soldiered on the circuit board but its a relatively easy fix, just hope that the board itself didnt get shorted out, if so you will need to replace the system, i used this website when i was overseas and all my stuff got to me with in 10 days...
Dec 30, 2009 | Altec Lansing Multimedia Computer Speakers
Epson R280 was plugged to 220V by mistake
you can not fix it by your self you need the power input place and if it had effect the buffer device than might it would take alot mony to get fixed...
Jun 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Plugged into 220V outlet by mistake! Help!
I don't know for sure, but I suspect that if you open it up, there should be a fuse near the power supply portion of the unit. It may have taken the hit for you and can perhaps be replaced easily. (As a disclaimer... be sure the unit is not plugged in when you open the case! And only replace the fuse with another of equal rating.) If it's not a fuse, then you probably smoked the primary winding of the transformer. If it got past that, you may have popped the rectifier and/or capacitor(s) in the power supply.
Oct 20, 2006 | Technics SA-DX930 Receiver
168 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
