Question about Acer V193w LCD Monitor
1440 900 display resolution
My monitor does not show screen while starting
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Uninstalation of monitor driver HP2509 stopped monitor to display.shows blank screen in vista desktop
The monitor driver only tells the video card which video resolutions are supported by the monitor. The video card is probably set to the wrong resolution. You can boot into safe mode, set the screen resolution to one the monitor supports, and you should be good to go. You don't actually "need" a monitor driver.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
Tried to enlarge the screen and screen went black and now showing this! I turned it off and hit F8! It came on I pressed safe mode! I tried to get on Internet and it locked up again ! Back to this scr
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor.
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
Oct 20, 2012 | Computers & Internet
Change display properties
To change your screen resolution
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
Aug 27, 2012 | Computers & Internet
A few months ago my screen started distorting the picture now and then, and then would revert back to being fine. Now it stays mostly like that. I have it set up as an extended display from my laptop. I...
The resolution for the extended display could be wrong or on a setting the monitor cannot display. When you tell the computer to extend the display their should be a resolution drop down. Change it for the extended display monitor ( Click Advanced Display Settings or you may have to click the second monitor to see the resolution for it)
Jun 01, 2017 | Acer AL1912 19" LCD Monitor
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
Half of monitor screen shows on the projector.
You will need to set your computer to the correct display properties.
This you can do by either going to presentation mode.
Alternatively,
on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy.
( for information: display1 is the resolution meant for your computer).
Please do rate this solution and Thanks for usinf FixYa!
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Acer V193w LCD Monitor Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
