Question about Nokia BH-208 Wireless Headset
Device driver - Nokia BH-208 Wireless Headset
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
Tip
This is about a utility called DriverEasy and how to take the hassle out of...
This is about a utility called DriverEasy and how to take the hassle out of keeping your device drivers up to date.
DEVICE DRIVER BASICS
A device driver is a piece of software that sits between the operating system and the hardware. It enables the Operating System (OS) to access the device using standard system calls. Drivers provide a convenient way of interfacing a variety of devices without the OS or applications requiring the details of directly communicating with the hardware in question.
When you install a new device, you also install its driver. When the system boots up, it loads the installed device drivers into the kernel, making the devices they support available for use. In fact, when you plug-in a new device, Windows automatically starts the New Device Driver Wizard to guide you through the process of downloading the relevant driver.
Every peripherals uses devices drivers because of flexibility they provide. This even includes motherboard components such as temperature management hardware.
DRIVER PROBLEMS
The driver flexibility made possible by device drivers leads to a problem. For example printers, because each make and model has its own requirements, you'll have install exactly the right driver if all the features are to work as they should.
However those drivers are not only hardware-specific, but also operating system-specific. When Microsoft release a major new Windows update, your printer's manufacturer needs to create a new driver specifically for that version of Windows. Until this happens, your printer is basically useless.
WHAT YOU'LL NEED
DRIVEREASY
Fortunately, there is now software dedicated to analyzing and maintaining your operating system's driver structure in an efficient way. This free utility finds and upgrades out-of-date device drivers. You'll find it at www.drivereasy.com.
on Jul 12, 2010 | Computers & Internet
Did not install drivers for this device (Code 28)
Windows error code 28 indicates a missing or damaged driver file, which can keep devices connected to your computer from working correctly. This code appears in Windows XP, Windows Vista, Windows 7 and Windows Server editions. In most cases, you can stop this code from appearing by installing a new driver or by removing the old driver and replacing it with a different one.
Drivers
A driver is any piece of software that controls such devices as your graphics card, keyboard or printer. Windows operating systems come with many device drivers, and installs them automatically. Specialty devices, such as scanners, cameras or add-on cards, usually have their own proprietary drivers, which must be installed from a disk or downloaded file. b> Troubleshooting b> When any modern version of Windows can't find the driver to operate a device, it displays error code 28. You can find out more about the problem by opening Windows Control Panel, then choosing "System." Select the "Hardware" tab, then choose "Device Manager." From the Device Manager, select the problem device. In most cases, the device will have a small yellow exclamation mark next to its listing in the Device Manager. Right-click the device and choose "Properties" to see more information about the problem. Driver Installation b> You can install a missing driver on your own from the Properties dialog. Click the "Reinstall Driver" button and choose to install the software automatically. If automatic installation doesn't work, and you have a downloaded driver or one on disk, choose to install the driver from a specific location, then direct Windows to the correct file. If you don't currently have a driver for the device, visit the support section of the manufacturer's website. Most companies offer downloadable, updated drivers for all their devices. b> Considerations b> Sometimes Windows doesn't correctly recognize a device, even after you've installed a driver. This could happen because you used the wrong version of the driver or a driver meant for a different model of the device. Your existing driver may also be damaged and require reinstallation. In some cases, a fault in Windows may cause it not to recognize devices correctly. Microsoft offers an online diagnostic tool called Microsoft Fixit that can scan your operating system and tell you why code 28 is appearing.
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Mar 15, 2012 | Microsoft Computers & Internet
What is code 1 and code 28 and how to repair?
All computer hardware needs device drivers to communicate with the operating system. In Windows quite a few device drivers are included with the installation. But for a lot of hardware, special device drivers are required. If drivers are corrupted or not installed properly, Windows will report a device error. One of the device errors that the Windows Device Manager can report is a code 28 error.
A code 28 error means that there is no driver installed for the hardware device. Most likely Windows does not have a default driver for the device, or it would be installed. This means that a special driver from the hardware manufacturer is required. The code 28 error can occur for any type of device, USB devices, audio devices, video devices, etc. In general however the error will occur for the more exotic hardware since Windows already supports quite a few common devices by default.
To fix code 28 errors, it is required to install the drivers for the device that is causing the code 28 error. You can use the device manager to update the drivers. Select the device in error, right-click the device and in the pop-up menu select Update Driver Software. Windows will ask you for the location to install the drivers from, so make sure you download the drivers for the device from the hardware manufacturer’s website first, and select the local folder where you saved the download drivers for the update.
If you can not find the drivers for the device in error, or are not comfortable in using the Windows Device Manager, you can also use a driver update tool to find, download and update all device drivers for you. A driver update program will accurately identify your hardware, including the device in error, and automatically install the latest drivers for it. This will solve code 28 errors.
It is also recommended to have Windows configured for automatic updates. This will ensure that any new drivers that are supported by Microsoft will automatically install or get updated, so that your computer will be compatible with as many devices and hardware as possible.
Code 1:
Error (Code 1) is a known error that is caused by outdated or corrupt drivers. Failure to keep your drivers up to date could result with system malfunctions and device problems.
Solution: It is highly recommended that you update your drivers now to fix the problem.
More Info: Device Manager may report about and provide resolutions. To view the error codes, follow these steps:
Click Start, click Run, and in the Open box, type control panel.
In Control Panel, double-click System, click the Hardware tab, and then click Device Manager.
Double-click a device type. For example, double-click Modems to see the devices in that category.
Double-click a device to view its properties. If an error code has been generated, the code appears in the Device Status box that is on the General tab.
Jun 22, 2010 | Intel Computers & Internet
Unknown device sm bus controller
What I do in such circumstances is run a little piece of freeware called "Unknown Device Identifier" which does a pretty good job of telling me what device is not working properly, identifying the manufacturer, which allows me to look up the support site and get the driver necessary to correct the problem. I've found that to be the quickest and surest way to resolve such issues.
You can also try double clicking the device in device manager and then selecting "update driver" and see if Windows can locate it on your hard drive or search the internet [providing you have a working connection] to find the appropriate driver and install it. I find it works about half of the time.
There is are other trouble shooting methods and the Microsoft Knowledge base does the most straight forward job of defining them so rather than reinvent the wheel I'll present them as written there:
The main reason for Unknown Device to display in your Device Manager is because you have a device that is not working correctly. To fix this issue, obtain an updated driver for the device.
Use the following methods to enable Windows to recognize your device. Method 1: Windows Update loadTOCNode(3, 'moreinformation'); Visit the following Microsoft Web site to see whether the Web site autodetects an updated driver for your device. Install all recommended drivers. http://www.windowsupdate.com (http://www.windowsupdate.com) Method 2: Download and install the latest driver from the Internet loadTOCNode(3, 'moreinformation'); When you download a driver from the Internet, download the Windows XP version of the driver when multiple Windows versions are listed. Use one of the following options:
  • Visit the Web site of the computer manufacturer if the device came with the computer.
  • Visit the Web site of the device manufacturer if the device was installed after you purchased your computer.
  • Visit the Web site of the device manufacturer if the device was preinstalled on your computer and the computer manufacturer does not have an updated driver.
Look for a Drivers section or a Download section on the manufacturer’s Web site, and search for the device name. Download and install the Windows XP version of the driver. Advanced user section loadTOCNode(2, 'moreinformation'); This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus) Causes of unknown devices in Device Manager loadTOCNode(3, 'moreinformation');
  • The device does not have a device driver: When a device driver for a device is not available, Device Manager displays the device as Unknown Device and puts it in the Other devices branch. This is very common with universal serial bus (USB) and Institute of Electrical and Electronics Engineering (IEEE) 1394 composite devices. Also, a status of Error Code 1 or Error Code 10 may be displayed when you view the properties of the device in Device Manager.
    Note Most USB and IEEE 1394 devices function correctly without additional device drivers because they are configured by the drivers that are included with Windows for these bus types. However, an additional device driver is needed if the device does not fit the defined and supplied Windows class drivers. If the bus cannot identify the device, it interprets the device as a composite device and then reports it as such in Device Manager.
  • You are using a Microsoft Windows 98 or Microsoft Windows 95 Device Driver: You cannot use virtual device driver (.vxd) files that are common to Windows 98 or to Windows 95 drivers in Windows XP. If you try to install them on your Windows XP-based computer, the device may be listed as unknown in Device Manager. This typically occurs when the device driver manufacturer does not correctly differentiate between the two drivers or assumes that Windows XP can use Windows 98 or Windows 95 .vxd files.
  • Unrecognized Device ID: Every hardware device has a special identifier that is used by Plug and Play. This identifier can include several different types, such as vendor ID, device ID, subsystem ID, subsystem vendor ID, or revision ID. If a device ID is not present, or your Windows XP-based computer does not recognize the device ID, Device Manager may list the device as unknown.
    Note Software programs that require virtual hooks into hardware may create these devices. Additionally, devices that bridge between bus types, such as a device driver that enables a parallel port device to emulate a SCSI or an AT Attachment Packet Interface (ATAPI) bus, are also known to generate an unknown-device response in Device Manager.
  • Faulty Hardware or Firmware: Faulty hardware or firmware may cause a device to be displayed as Unknown Device in Device Manager. Software-only device drivers do not expose a device ID, and there is no standard method for installing these devices. Some manufacturers install the device by using the InstallShield installation program or a similar method. Be aware that software installed by other methods may not be completely removed when the device is removed in Device Manager. Therefore, you may have to check the registry to verify that all entries are removed.
Feb 04, 2010 | Computers & Internet
I have 12 Drives All 12 Drives are found but when I burn a DVD The Some drivers fail and it is not the same ones all the time
Usually, a driver update is used as a solution to an issue with how Windows works with a piece of hardware.
Updating a driver can also enable new or updated features for the hardware.
To access Device Manager, use any of the following methods:
  • Click Start, click Run, and then type devmgmt.msc.
  • Right-click My Computer, click Manage, and then click Device Manager.
  • Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager.
  • Type the following command at a command prompt: start devmgmt.msc
You can use Device Manager to change the way your hardware is configured, and to change the way your hardware interacts with your computer's programs. With Device Manager, you can update device drivers for hardware installed on your computer, modify hardware settings, and troubleshoot problems.
Device Manager enables you to:
  • Determine if the hardware on your computer is working properly.
  • Change hardware configuration settings.
  • Identify the device drivers that are loaded for each device and obtain information about each device driver.
  • Change advanced settings and properties for devices.
  • Install updated device drivers.
  • Disable, enable, and uninstall devices.
  • Reinstall the previous version of a driver.
  • Identify device conflicts and manually configure resource settings.
  • Print a summary of the devices that are installed on your computer.
If the device is experiencing a problem, the type of problem is displayed. You might also see a problem code and number and a suggested solution. If you call a support line, this number can be useful for determining and diagnosing the problem.
How to install a new driver from Device Manager loadTOCNode(2, 'summary');
  1. Double-click the type of device you want to update or change.
  2. Right-click the specific device driver you want to update or change.
  3. Click Update Driver to open the Hardware Update Wizard. Follow the wizard instructions.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver, such as error messages when you access the device, faulty behavior of the device, or even the inability to start Windows.
Windows XP provides this roll back to a previous, working, device driver:
  1. Right-click the device for which the previous version of the driver is desired and then click Properties.
  2. Click the Drivers tab.
  3. Click Roll Back Driver.
If you cannot resolve the problem with these instructions, contact the manufacturer.
Dec 04, 2009 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Aug 03, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Nokia BH-208 Wireless Headset Logo
16 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
