Question about Westinghouse LTV-27w6 27 in. LCD HDTV
Unresponse to remote or tv case buttons to change or power
Remote became unresponsive, and the only solution is to switch the TV off/on. Then the remote failed completely, and we couldn't even use the case buttons to power off...we had to pull the plug and restart and reprogam and the whole package and do not know for how long it will be ok, could be one hour or 10 minutes.
  • 1 more comment
  • Anonymous Nov 23, 2007
    On occasion when sound is muted the TV becomes unresponsive to remote inputs and the buttons on the side of the TV do not work either. It's not a remote issue, it's a TV issue. The only way to correct the problem is to unplug the TV momentarily.
  • Anonymous Oct 01, 2008
    I have the same problem. Remote and TV unresponsive - have to unplug TV and then plug in again to get it to work.
    Railguy
  • computerinst Jan 13, 2009
    Got an LTV-27w6, suddenly no picture, no sound just the blue LED on the side on. Unplugged and pluged back on for at least 20 times, it worked for only a few days. I noticed that remote was unresponsive and channel display stayed on if I surfed the channels too fast. Now I can't get back on anymore. Westinghouse customer service was no help at all. More expensive to fix it than buying a new one. Never again will buy from Westinghouse!
  • 790 Answers
Try to change the battery!
Posted on Oct 09, 2007
Kogan TV remotes
What about them? Where to get them? This has caused much angst online, with some people saying Kogan is unresponsive.
The Logitech Harmony remotes will operate a Kogan, and you have the choice of a range of models. I have used one on a LG TV and it worked OK, but some buttons became mushy after about 2 yrs.
Aug 07, 2014 | Televison & Video
Remote is unresponsive to tv and lcd light remains on
if it works from very close range the receiver is the issue.
Nov 02, 2012 | Televison & Video
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive.
The problem is most likely a short in the switch panel on the front of the TV. The remote won't work because the TV thinks that you are using the manual buttons on the front, and the manual buttons override the remote. Have the front button panel replaced....it's under $200.00 - or you could solder the switches apart and just use the remote.
Nov 01, 2009 | Toshiba 36A43 36" TV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Oct 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead; unresponsive, no raster, nothing.
You may have lost the standby power supply. There should be a 5v supply that runs with the set in standby, see if you can find that. Also check for B+ (around 160VDC) at the large filter capacitors in the power supply.
Oct 06, 2008 | Toshiba 36A60 36" TV
TV STUCK IN "DEMO MODE"
I had the same problem with my TV, This is the way i fixed the problem i took a hammer and banged on the menu button a few times and know the tv works great!!!. Little weird huh:)
Jul 28, 2008 | Toshiba 35A44 35" TV
RCA P52960 R/P lost all controls..remote & panel!1 HELP
Hello ChupacabraV2,
This is a scene from some horror movie. I bet , if you unplug it, the TV will still be on!!....Just messing with you. Its been several days since you posted this problem. Please post update if there is any change. I don't think you have the TV on all this time. Let us know
Best regards
circuitcity
May 31, 2008 | RCA P52960 52" Rear Projection Television
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
190 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
