Question about Texas Instruments TI-89 Calculator
WON'T TURN OFF
I've tried numerous times to turn the calculator off, and it does so for a split second, but then it turns right back on. It seems the only way to turn it off is to take out the batteries? It used to work fine until a couple weeks ago. Any ideas?
  • Cam_G Apr 26, 2008
    AHHHHHH!!!! JUST TURN OFF!!!
    I know someone has a solution for this, it has something to do with changing settings, but I can't find it again....
    Does anybody know? I'm not doing an update, I don't have a cable.
  • baseballneal Sep 16, 2008
    I can not get my TI-89 to shut off. When i turn it off, it shuts down and then powers right back up.
I have just same problem.. but how i can clean under the on button?/
Posted on Apr 16, 2008
Under your On button might be some dirt, that keeps triggering the On button, and thus, keeps it on.
Clean under the On button
Posted on Mar 24, 2008
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Ps3 won't start up
Try to refresh the account and access it again. Make sure that credit card information is safe.
Mar 09, 2013 | Sony Playstation 3 (PS3) Console
My samsung galaxy pocket won't turn on!!
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 29, 2012 | Cell Phones
How to calculate log into decimal?
To convert a single symbolic result to a numeric result, press right-shift ENTER to invoke the ->NUM command.
To have all results come out in numeric form, turn on the numeric flag. Press MODE C down-arrow down-arrow left-arrow +/- ENTER ENTER .
Aug 27, 2012 | HP 50g Graphic Calculator
It takes too much time to turn on
Is the screen off during this time? it might be the batteries Try buying new batteries. I recommend you rechargeable batteries. If it doesn't work try installing the latest firmware from hp.com/calculators
Dec 26, 2011 | HP 50g Graphic Calculator
I've had my ti-86 for a very long time & recently it just quit working. I changed the AAA batteries & the back up battery & it will not come back on. Please help???!!!!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Dec 02, 2011 | Texas Instruments TI-86 Calculator
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Texas Instruments TI-89 Calculator Logo
268 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
